Dear Administrator,
Good day to you. The following message was originally
sent to Chips. However, was told by Chips to relay it
to you. Therefore, would greatly appreciate it if you
can kindly put a light into my woes. Thank you.
I am currently facing a problem whenever I try to put
in or reply a thread in AW Forum. Whenever I finish
typing and click "Submit" there is prompt that
says "cannot find the internet website...." or in
worse cases, "you have performed an illegal
operation.." or "an error has occured...". Can you
please check as to why is this happening? I don't find
these problems with other websites.
Thanks.
Problems replying posts
KillerB
, Dec 28 2002 10:26 AM, 4 replies to this topic
Posted 30 December 2002 - 10:48 AM
Dar,
It only happens to the pc at my work place. For my
home pc, it's ok. And, yes, it's IE5. Why?
Posted 30 December 2002 - 06:23 PM
It may be because your IE5 is a little unstable. You
may want to try to either 'detact and repair' it or
reinstall.
reinstall.
Posted 30 December 2002 - 10:37 PM
Same case with mine. My pc was using IE5 previously &
I was having this 'illegal operation' problem only
when accessing AW. After installing IE6 for about 2
weeks now, no single illegal operation occurs. It
really solves the problem. Good luck!
