"FUEL CONSUMPTION" for WIRA GLI
lcyew
, May 22 2003 04:15 PM, 133 replies to this topic
Posted 25 May 2003 - 10:48 AM
Wow..50 bucks for 560 KM is not bad la..bugger mine 2001 gli 1.5 also
less than that..bout 500 onli...but i rev quite high at times ler due to
only 3 gears so i tarik second gear to probably 80 onli release pedal to
a up shift..maybe thats y..
Posted 25 May 2003 - 12:13 PM
Mine is stock. Last month, I drove on old trunk road at 70-90km/h. One
full tank RM55 (40.7L) can last me 630km+.
Posted 25 May 2003 - 12:31 PM
Changing rims also will cause increase in fuel consumption? I thought
sport rims make your car lighter and conserve fuel. Anyone out there know
how to jimat on minyak rather than comparing whose care drink more?
Posted 25 May 2003 - 01:46 PM
Aiseh very easy wan if wanna driuve car without wasting petrol.change yer
driving mindet is the most important..i did that and it did really save
me 10-20 km..try to change gear about 2k rpm lor.dun tarik so high..and
wen u know u gona slow down, dun tekan pedal ie 100m to a junction..jus
let it roll lor..and 50m awah put into neutral.thats how i save
petrol..and keep rpm below 3k..then sure save wan
Posted 25 May 2003 - 05:42 PM
MrShaggy, you suggestion for manual can lar but for auto not possible. Go
fast a bit the car rpm already over 3k. What about using those expensive
engine oil like shell helix ultra? Can help to save?
Posted 25 May 2003 - 11:06 PM
low rpm = fuel eco?
My 1.5(A) rpm always <3k, even speed >100km/h. But still very thirsty.
Posted 26 May 2003 - 07:37 AM
For mine, when i reach around 120km/h to 125km/h its exactly 4k. Can
adjust it down? If too low, car kaput in the morning. This is what
happen. Morning time, everytime engage reverse gear, car rpm suddenly
drop to below 500. :-)
Posted 26 May 2003 - 10:42 AM
I think all these xxx rpm at xxx speed cannot be adjusted. If you want
lower rpm at higher speed, you need to change the gear-ratios in the
gearbox, which is not easy, if not impossible.
This rpm at xxx speed has nothing to do with your idling rpm.
Just my opinion, I might be wrong.
Posted 26 May 2003 - 11:22 AM
boboi,
i think one can change to bigger rim diameter to lower the rpm at higher
speed. it is not by much though. i might be wrong too
