Cleaning the air cond belt.
alienfx
, Sep 23 2006 08:23 AM, 13 replies to this topic
Posted 23 September 2006 - 08:23 AM
Whats the best method of cleaning the air cond belt?When its noisy, i will
use the belt dressing spray and it will become quite.But after few days it
will become very noisy.More noisy than previously.I think its because dirt
have sticked to the lubricant from the belt dressing spray.The lubricant
feels like wd40.The belt will become quite again when i wash it with car
shampoo.My belt is 4 months old only.How often we have to change the
belt.What else could be done to stop the squeaking noise from the belt?
Posted 24 September 2006 - 04:07 PM
bro, try to apply some wax on the belt. The best is go buy those white
candle and let the engine run. Rub the candle on the side of the belt and
bottom of the belt. It will help eliminate the sqeauking sound. Becare
though when doing it cause your engine is running and you won't want ur
hand to get caught into the belt. Another reason for belt noisy is because
the belt tension is not strong or loose belt. Did you jusr change the
belt ?
belt ?
Posted 26 September 2006 - 09:17 PM
Belt was not adjusted.The candle thing is new to me.Will try it.Candle has
low melting temperature.I wonder if it can stay sticked to the belt due to
high engine heat.
high engine heat.
Posted 27 September 2006 - 09:35 AM
i am facing the same problem with you. when lion first started engine,
engine counterpart is very noisy. w/shop told that was air cond belt
problem. however, when press petrol, no more sound. normally, 5 mins
later from first started, the noise will stop.
never try candle before but will try WD40 to see how effect it is.
Posted 29 September 2006 - 12:41 PM
dear ali,
Never use wd40 on your belts!!!. yes.. if may solve the noise but long
run it will hardened the belt. Use special type of grease.It can be
obtain at any spare's shop.
cheers.
regards,
cheers.
regards,
Posted 30 September 2006 - 07:13 AM
beli aje belting spray....ade dijual di JJ , Carrefour...dan di spareparts
kete...ade banyak brand.... salah satu nye STP ..tapi selalunye kalau
belting bunyi... tegang kan sikit tension nya tuu...tak yah spray pun..cuma
advantage spray ni boleh membersihkan dan juga memanjangkan sikit jangka
hayat belting tersebut..
just my 1/4 cents...heheheh is it true...???? dont try if dont trust it..
hehehehe...
hehehehe...
Posted 01 October 2006 - 06:14 PM
alienfx, when u rub the candle to the belt you only get the wax from the
candle not the whole thing. It acts like a grease. Eg. when you rub your
hands around candle your hand will feel oily isn't ?
Posted 01 October 2006 - 06:34 PM
Tried the candle method.It works.Whole candle gone.Just
dissapeared.Hehehe...
