vibration
chting
, Jul 23 2003 05:26 AM, 7 replies to this topic
Posted 23 July 2003 - 05:26 AM
hi..i using wira 1.5 manual 2001, i facing the problem is my car will
vibra when i open the car aircon?? if i off the aircon it very smooth lo,
So i just want to know that is other wira also some or only my wira got
problem??
pls advise!! thanks..
problem??
Posted 23 July 2003 - 10:33 AM
For manual, I guess it shouldn't happen. But for auto yes lor. At least it
happens to my 2000 Wira 1.5GLi auto. Still unable to solve it till
today ..
today ..
Posted 24 July 2003 - 12:52 AM
my RPM 1k, after turn on the aircon drop to 900 - 800, i think still ok,
right!! but only i increase the temp higher it got vibration lo.. when i
turn the temp to minimum it stop vibra!!although the aircon still on..
Posted 24 July 2003 - 10:52 AM
hi just my 2 cents worth,
i think you need to check the compressor mounting and the alignment of the
pulleys and drive belts to the engine pulley. sometimes a slight mis
alignment can cause this problem. a misalignment can cause strain on your
engine which is why it is vibrating so much despite you rpm needle reading
normal
take it to a good air-con shop to get it checked.
normal
Posted 25 July 2003 - 05:05 AM
yalor...i also don't no what leh!!
but my car only 2 year pass, i only
use for normal drivela.....
how much if really want to check or repair
the thing???
the thing???
