rear strut bar
Aquua
, Mar 24 2003 12:25 AM, 22 replies to this topic
Posted 24 March 2003 - 12:25 AM
am planning to put rear strut bar which similar in wira 1.6 or 1.8.My friend told me that it will increase the stability in hard corner.i don't understand that the peace of metal will provide good handling..how it works?..Where should i find it?how much does it cost?is it available in chop shop..
Posted 26 March 2003 - 09:19 AM
I think what he meant was the rear anti-roll bar as fitted to the wira 1.6 and above.
There is a real and effective advantage to have the proper anti-roll bar fitted to the rear. It balances the understeering tendency of your car in tight corners.
Posted 26 March 2003 - 10:09 AM
so can this be done to wira 1.5? need to change anything? chop shop got?
Posted 26 March 2003 - 11:42 AM
ayo...v-spec..mistake la...the thing is not rear strut bar..it's called anti roll bar..btw,how much u install that one?..where u find it?..
Posted 28 March 2003 - 03:01 PM
u r looking this thing same as i looking for!!!this thing only can fixed on wira 1.6 .1.8 only.if u r wira 1.5 u must modifie that welding a piece of holder on ur lower arm!!!this is normally people do it.if u worry about it u another thing is u must change 1 pair of 1.6wira or mivic lower arm.that all friend!!
Posted 02 April 2003 - 12:36 PM
really aaa?
muz modify aaa? i tot it's all the same "lower-arm"
wat abt the new wira 1.5?
btw, how much does tis anti-roll bar cost
and separate the workmanship for modifying $$$...
seen brothers selling below RM20 similar or ciplak 1...
got difference aa if use ciplak 1
thanks.
thanks.
Posted 02 April 2003 - 01:23 PM
I'm having rear up and bottom fixed and seriously I don't feel any
difference or maybe the improvement is slightly improved? I'm not sure
about that... The rear bottom can get it very cheap price... practically
it's just a steel bar while top on is similar to front anti-roll bar.
Posted 02 April 2003 - 02:52 PM
aik...
rear one got top & bottom...
bottom seen b4 lar... top 1 ler... niop...
where it's located... and cost for both (include fixing)
Btw, ur car is 1.5 wira or etc.
cheers.
cheers.
