GSR and Putra gearbox
Posted 21 March 2003 - 06:50 PM
I managed to literally break my 1.8T gearbox :(
And now i need to change it. I am wondering if the 1.8T and Proton 4G93 DOHC gearboxes are interchangeable?
I have this info:
GSR
Type Manual
Model W5M33
Gear ratios
5 Speed
1st 2.916
2nd 1.684
3rd 1.115
4th 0.833
5th 0.666
Reverse 3.166
Primary reduction 1.680
Transfer gear 1.090
Final drive gear
- front 2.936
- rear 4.525
Proton (model number of gearbox dunno la)
1st 3.083
2nd 1.947
3rd 1.285
4th 0.939
5th 0.777
reverse 3.083
Will I damage the engine if i use the std gearbox instead of W5M33?
What is the impact of using the proton one?
Hope some of u can help....
tks
terence
Posted 22 March 2003 - 01:45 AM
fren,
As for the standard 1.8 wira gearbox, it can't handle the torque of a turbo motor so if you install it, you're looking for trouble.the gears will shear and break...
Posted 22 March 2003 - 02:29 AM
Posted 22 March 2003 - 05:09 PM
you're right sifu! i've seen even the VR4 using proton 1.3 gearbox! pick up wise and save petrol somemore...eh?! how come?
many many gearbox you can use if own a VR4! proton 1.3~1.8,mirage NA or turbo,perdana 2.0 and the lock one!
Posted 23 March 2003 - 12:18 AM
Anyone sellng a GSR GB? or LSD one even?
Posted 23 March 2003 - 05:00 PM
LSD one huh? damn hard to get lor...
mivec 1.6 gb i think come with LSD, you can try and look for it in kedai potong! oh, and the mirage 2wd gb also not bad! :)
anyway, the best way to get back ur ori gb lar...
Posted 25 March 2003 - 09:54 AM
Anyway I wouldn't recommend the 1.3 gearbox even if the gear ratios were optimal..
Posted 25 March 2003 - 12:05 PM
my fren with VR4 1.3 gearbox said that his car pick up better then the stock VR4 gearbox and top speed also not really affected cos he can go up to 200km/h
any time he wanted to...
that mean, we should use back the ori one then? how about the 4WD one? what happen if we lock it?
Posted 25 March 2003 - 01:44 PM
i am driving a putra with a gsr engine (standard). I am not sure about what gear box the car is running, i think it is the original gsr gearbox because i bought the 1/2 car (gsr) from a 1/2 car dealer in kl.
At 110km/h in 5th gear, the rpm reads 3,600rpm. If i am not mistaken the standard putra / GTi gearbox has a higher ratio (lower rpm at 110km/h). Can anybody confirm this.
Posted 26 March 2003 - 04:02 PM
You can always jack your car up and check the gearbox (if you can't find the gearbox number which is located on top of the clutch housing). It is very easy to spot a 4WD gearbox as there's the protruding shaft that drives the rear diff.
