engine guides about your proton power & those who wanna upgrade.
MITSUBISHI
4G13 (1298cc)
-Serial 4 cylinder SOHC8 valve, Electro- carburetor, NA
67 ps (49.28 kw) / 5500 rpm, 10.6 kg*m (103.95 N*m) / 3500 rpm
-Serial 4 cylinder SOHC12 valve, Electro- carburetor, NA
79 ps (58.10 kw) / 6000 rpm, 10.8 kg*m (105.91 N*m) / 3500 rpm
-Serial 4 cylinder SOHC12 valve, ECI-MULTI, NA
88 ps (64.72 kw) / 6000 rpm, 11.0 kg*m (107.87 N*m) / 3000 rpm
4G15 (1468cc)
73 ps (53.69 kw) / 5500 rpm, 11.9 kg*m (116.70 N*m) / 3500 rpm
-Serial 4 cylinder SOHC8 valve, ECI-MULTI, NA
82 ps (60.31 kw) / 5500 rpm, 12.6 kg*m (123.56 N*m) / 3000 rpm
85 ps (62.52 kw) / 6000 rpm, 12.5 kg*m (122.58 N*m) / 3500 rpm
-Serial 4 cylinder SOHC12 valve, ECI-MULTI, NA/MVV
91 ps (66.93 kw) / 6000 rpm, 12.4 kg*m (121.60 N*m) / 3000 rpm
-Serial 4 cylinder SOHC12 valve, ECI-MULTI, MVV lean-burn
94 ps (69.14 kw) / 6000 rpm, 12.4 kg*m (121.60 N*m) / 3000 rpm
100 ps (73.55 kw) / 6000 rpm, 13.3 kg*m (130.43 N*m) / 3000 rpm
-Serial 4 cylinder DOHC16 valve, ECI-MULTI, NA
110 ps (80.91 kw) / 6000 rpm, 14.0 kg*m (137.29 N*m) / 3000 rpm
4G61 (1595cc)
125 ps (91.94 kw) / 6500 rpm, 14.7 kg*m (144.16 N*m) / 4500 rpm
130 ps (95.62 kw) / 6500 rpm, 14.7 kg*m (144.16 N*m) / 5200 rpm
-Serial 4 cylinder DOHC16 valve turbo, ECI-MULTI, Turbo
145 ps (106.65 kw) / 6000 rpm, 21.0 kg*m (205.94 N*m) / 2500 rpm
160 ps (117.68 kw) / 6000 rpm, 22.5 kg*m (220.65 N*m) / 2500 rpm
4G63 (1997cc)
-Water cooling serial 4 cylinder DOHC16 valve, ECI-MULTI, NA
145 ps (106.65 kw) / 6000 rpm, 17.8 kg*m (174.56 N*m) / 5000 rpm
160 ps (117.68 kw) / 6500 rpm, 19.0 kg*m (186.33 N*m) / 4750 rpm
170 ps (125.04 kw) / 6750 rpm, 19.5 kg*m (191.23 N*m) / 5000 rpm
-Water cooling serial 4 cylinder DOHC16 valve IC turbo, ECI-MULTI, Turbo
with intercooler
220 ps (161.81 kw) / 6000 rpm, 30.0 kg*m (294.20 N*m) / 3500 rpm
with intercooler
240 ps (176.52 kw) / 6000 rpm, 31.0 kg*m (304.01 N*m) / 3500 rpm
-Serial 4 cylinder DOHC16 valve IC turbo, ECI-MULTI, Turbo with intercooler
250 ps (183.88 kw) / 6000 rpm, 31.5 kg*m (308.91 N*m) / 3000 rpm
260 ps (191.23 kw) / 6000 rpm, 31.5 kg*m (308.91 N*m) / 3000 rpm
270 ps (198.59 kw) / 6250 rpm, 31.5 kg*m (308.91 N*m) / 3000 rpm
272 ps (200.06 kw) / 6500 rpm, 35.0 kg*m (343.23 N*m) / 3000 rpm
280 ps (205.94 kw) / 6500 rpm, 39.0 kg*m (382.46 N*m) / 3500 rpm
4G67 (1836cc)
135 ps (99.29 kw) / 6300 rpm, 16.2 kg*m (158.87 N*m) / 4500 rpm
4G91 (1496cc)
-Serial 4 cylinder DOHC16 valve, Electro- carburetor, NA
97 ps (71.34 kw) / 6000 rpm, 12.8 kg*m (125.53 N*m) / 3500 rpm
115 ps (84.58 kw) / 6000 rpm, 13.8 kg*m (135.33 N*m) / 5000 rpm
4G92 (1597cc)
-Serial 4 cylinder SOHC16 valve, ECI-MULTI, NA
112 ps (83 kw) / 6000 rpm, 14 kg*m (138 N*m) / 5000 rpm
145 ps (106.65 kw) / 7000 rpm, 15.2 kg*m (149.06 N*m) / 5500 rpm
-Serial 4 cylinder DOHC16 valve, ECI-MULTI, MIVEC/MIVEC-MD
175 ps (128.71 kw) / 7500 rpm, 17.0 kg*m (166.71 N*m) / 7000 rpm
4G93 (1834cc)
-Serial 4 cylinder SOHC16 valve, Electro- carburetor, NA
110 ps (80.91 kw) / 6000 rpm, 15.7 kg*m (153.96 N* P <ؒH MsgType n the po 8 9 P :c D(! sTitle H 9 (ba0b MsgType 9 8hA H d h
last_poster_id '1', ' A A D3* L Asia/Kuala_Lumpur ` A h_ JModerator , '', 8 @
Engine power specs
Denic
, Apr 09 2004 07:35 AM, 1 reply to this topic
