Any Fully Mod NA Proton`s Car That Can Beat TypeR?
keong
, Feb 19 2002 05:31 PM, 217 replies to this topic
Posted 19 February 2002 - 07:58 PM
give me the money, the car..and i will get it modded to out run drag the honda. NA of course..no supercharging, no turbo, no nitrous, no laughs either...
Posted 20 February 2002 - 09:27 AM
$ for $, no NA Mitsu/Proton engine can match to an equivalent NA Honda engine.
This means that if you spend RM10000 on a 1.8 Proton engine, it will never produce the same performance as spending RM10000 on an equivalent 1.8 Honda engine.
Btw, RM10000 is about the right amount needed to mod a 1.8 4G93P engine to put out the same power as a stock 1.8 B18C-R engine.
Posted 20 February 2002 - 02:49 PM
Sean,
What are the mods needed on a 4G93P to be able to produce the same power as the B18C type R?
Posted 20 February 2002 - 02:56 PM
fuahh, you guys should check out mat speed super putra at www.teammatrix.com.my that car done a super mod yet hp claim at 180hp where else a Integra 1.8 can pump up to 200hp stock, check out the super putra and see the mods i believe the amount of money that charlie spend is more then 10krm, hehehe running on LEDA suspension, ofcourse is expensive hehehe, though the low end torque is marvellous
Posted 20 February 2002 - 03:57 PM
If money is no object, then it is definitely possible to mod a NA proton to beat a Type-R. It certainly takes a LOT more than RM10K to make a Putra pump out 200hp.
Posted 20 February 2002 - 07:34 PM
Pleae do not compare the Matspeed SP with a stock ITR. You`re not comparing apples with apples. A stock ITR wouldn`t stand a chance.
Posted 20 February 2002 - 10:42 PM
Can compare Mitsu & Honda. Which is richer ? Who has more technology. Who has experience in running F-1. The answer is most likely `HONDA`
Of course comparing a stock ITR and Matspeed SP is not comparing apples with apples. The ITR is like a Pentium 4 while the SP is like a Pentium Celeron.
Posted 21 February 2002 - 03:10 AM
mitsu also not bad leh... like the evos and quite well known in rally!
seldom heard hondas in rally...
