1.5, 1.6, 1.8 Clutch & Flywheel
Virlution
, Apr 07 2003 03:45 PM, 7 replies to this topic
Posted 07 April 2003 - 03:45 PM
Anyone know whats the difference between the proton clutch and flywheel?
Can a 1.5 use the 1.6 clutch? Or need to change the flywheel? How about
the 1.8? Same with the 1.6, can it use the 1.8?
Any difference in terms of performance, driving issues (leg pain due
clutch in to traffic jam), fuel consumption? Prices, anyone know the
price?
Posted 07 April 2003 - 09:06 PM
virlution,
1.5 to 1.6 can lar but to 1.8, i dunno can or not... change to bigger
flywheel and clutch not going to improve ur pickup... going up hill more
gagah lar, i think? if want pick up, just use your stock flywheel and
lighten it... :)
lighten it... :)
Posted 08 April 2003 - 01:07 AM
My brother just change his 1.5 wira (M) to 1.6/1.8 Mit. Super Touring
flywheel and lighten it. He said the pickup a lot better and the throttle
respond better.
respond better.
Posted 08 April 2003 - 02:56 PM
No need to lighten the flywheel, just replace to the lower cc one,
complete set. 1.8 to 1.6, 1.6 to 1.5.
Posted 08 April 2003 - 05:09 PM
Heard that its better to go for higher spec, but you recommend to go for
lower... sure or not?
Posted 16 April 2003 - 12:43 AM
how about for 1.3 wira ? which flywheel should i change to lighten it ?
Posted 16 April 2003 - 02:03 PM
Flywheels usually come in a match set with the clutch. This is because the
friction area on the flywheel needs to equal the one on the clutch and also
the mounting points for the clutch must be the same as you'll need to
re-drill.
For example if you change the flywheel on a 1.8 Proton you'll need to go to
a smaller diameter clutch too. And it's not a case of which model has a
"better spec" flywheel. If you go to a lighter flywheel, acceleration and
response is better as the flywheel is more or less dead mass once the car
is moving. However you will need more revs and clutch slippage moving the
car from standstill..
re-drill.
