temperature
iss2731
, Nov 07 2006 02:07 PM, 2 replies to this topic
Posted 07 November 2006 - 02:07 PM
Kereta saya merc model 123 230E tahun 84..Air tangki
menyusut..temperature stay kat 100 masa parking running dia normal...dah
check tak de bocor kat mana2 pun...mintak tolong rakan2 merc yang tahu
atau yg jumpa masalah sama
Posted 27 November 2006 - 02:14 PM
Check radiator, hoses & joints for leaks.
Check gaskets not leaking.
Check fan still works and fan relay/switch ok.
If still no joy, do a pressure flush of the entire cooling system. Replace
expansion tank/radiator pressure cap and thermostat.
It worked for my Vectra.
Posted 27 November 2006 - 11:14 PM
no obvious leakage, then possibilities are
- leaking into engine oil. Engine oil looks ok?
- leaking out into exhaust. check tailpipe for coolant.
