Lenkali, jgn le pakai immobilizer yg pakai keypad. Keypad
tak tahan lama. Pakai yg card type atau transponder.
Anyway, how much to change the ECU? How long will it takes?
pengalaman immobiliser problem?
muhdyusuf
, Mar 01 2003 10:01 PM, 11 replies to this topic
Posted 06 March 2004 - 01:58 AM
Macam ini saudara skelian, if you have immobiliser code then you can
start engine and than disconnect the immobiliser permanently that also
sometimes the ecu can go haywire again {rare instance}. if keypad faulty
then, change or borrow one , start then disconnct. but in the case of
unknown code or bought car from auction where code is unknown then
impossible to start you will have to change the ecu prefebaly to non
immobiliser type.The memory of the ecu is locked only the code will
unlock it.
unlock it.
