Windshield wiper
Posted 25 August 2004 - 12:15 PM
my windshield? This happens even during heavy or mild raining days?
Posted 25 August 2004 - 12:51 PM
2nd option put some silicone cream or similar, you know the stuff they use
to polish tyres etc on the wipers regularly.
3rd option use Rain-x or similar clones on the windshield.
Or do 2 & 3 at the same time.
Posted 25 August 2004 - 01:58 PM
squeaking problem still persist.
It may be the wiper, but eventhough its an OEM wiper, it is only 1 month
old. Can't be that bad right.
Honestly, I think its the RainX.
Posted 25 August 2004 - 02:37 PM
RainX works only when you drive fast enuff for the wind to blow the
droplets off. Also, you have to let the RainX completely dry (at least 5-6
hours) before using the wipers or it will ruin your wiper rubber and cause
squeaking and juddering.
A good windscreen polish and new wiper rubbers should fix your problem.
Dump the RainX.
Posted 25 August 2004 - 07:06 PM
As far as I know 1/2 the cause of chronic juddering of wipers is RainX. The other 1/2 is
caused by poor quality wipers and grease/oil on the windscreen.
This is what works (very well) for me- no juddering at all and a good clean wipe every time:-
Windscreen cleaned with Amway See Spray, then polished with AutoGlym Glass Polish. That's
all- don't add any funny stuff. You'll find that water beads and runs off the glass just as
good if not better than RainX.
Then make sure you use GOOD wiper blades. I'd recommend ONLY NWB, Valeo, EON (yes...
EON) or Wurth graphite coated natural rubber wiper blades.
Finally to get the inevitable grease off the windscreen use a GOOD screenwash. I've had
good results with Wurth Sabesto Blitz and AutoGlym screenwashes.
That ought to do it. Good luck
DIRAVI
Posted 26 August 2004 - 11:11 AM
seem to bear to part with so much dosh.
btw, where`s the best place to get Autoglym and Meguiars stuff? My
location in Klang Valley, preferably PJ/D`sara area.
Posted 26 August 2004 - 01:10 PM
Of course, the Wurth wipers I'm using now weren't cheap either... RM110 for the set.
But BOY they're good
Cheers
DIRAVI
Posted 26 August 2004 - 01:36 PM
to clean ur wiper every week to remove the dirt collected on ur wiper
blade rubber...
Posted 26 August 2004 - 04:00 PM
unevenly, leaving streaks. Some have rubber compounds that tend to be too
grippy and cause juddering when used in not-so-wet conditions. The worst
kind are those that kinda melt and stick to your windscreen whenever you
park your car for more than a few hours under the sun. I had to change my
blades once when driving back from Johor and bought some unknown brand in a
petrol station in JB. It lasted me 4 weeks. In contrast, the Valeo I use
right now has lasted me over 4 months and still wipes moderately clean.
I've gotten mixed results using Bosch. I suspect that they may be made in
different countries with different rubber compounds.
Posted 27 August 2004 - 08:57 AM
is oledi good enough liao lor. i didnt change my wiper for the last 3
years (almost).
