hi! anybody can comment on the rogers rogers rsa-428 amp or the 2 ch
rsa-228. want the cheapest decent amp for an entry level setup. maybe other
recommendations pls.
what about the blaupunkt gta-450?
thanks.
rogers rsa-428 amp any good
frez
, Sep 16 2005 08:05 PM, 4 replies to this topic
Posted 17 September 2005 - 11:35 AM
not sure about rogers amp. but blau GTA, it's pretty decent & cheap.
however beware that the inputs are 8V's.... if you are hooking it up to a
low Voltage output HU, say 2V or 2.5V ... you're going to be
dissapointed, it'll be very soft and you need to turn up your gains very
high.
If you are going for the GTA amp. Suggestion, find out how many volt out
at your HU rca outputs. If 2V or even 4V , I suggest you get a line
driver to boost it up to 7V or 8V or more. Then again the cost of the
blau gta amp + line driver total,.. u probably can afford something
better like Audio System.
high.
Posted 17 September 2005 - 12:17 PM
What's the input on the Audio System amp? I heard it is about 6V, is it
true?
What if I have an 8V HU? Can the amp support the HU output?
true?
Posted 17 September 2005 - 04:00 PM
my AS F2-280 has it listed between 200mv to 4v.the same as my previous
Alpine amp.it's variable and definitely not fixed like the GTA.i had the
same question you did and here's the replies from bro Bert and Kippo.
