Ron 97 For Citroen
albarade
Posted 20 June 2018 - 02:47 PM
albarade
  • 25 posts
Hello guy
I would like to check with you guys. I have Citroen  C4 Picasso 1.6 turbocharge. I severally experienced message " Engine fault. Repair needed'. When I checked with the mechanic, he told that my car have problem with the ignition issue according to ECU reporting. He also told that the problem was due to use of RON95. He suggested I use RON 97. Is that true my friends?
Posted 21 June 2018 - 10:48 AM
  • 71,854 posts
Is your engine knocking? If yes, than need higher Ron. Usually turbo charged engine requires higher Ron, unless it is tune to run on lower, but usually tuned for lower means less power....
albarade
Posted 22 June 2018 - 04:11 PM
albarade
  • 25 posts
Tq bro. My engine not knocking. With the error the impact of my engine is going slow. Dangerous to accelerate when to over take
Posted 23 June 2018 - 01:12 PM
  • 71,854 posts
With lower Ron, engine does not knock on low end. It happens at high end when more air fuel goes in and compression is higher
lingomalingo
Posted 02 July 2019 - 11:05 AM
lingomalingo
  • 362 posts
You can always check the owner manual or at the petrol lid what is the minimum RON required for this car.
Huarrrrgh
