Proton Waja Problems
tra.expand
Posted 04 June 2018 - 04:25 PM
tra.expand
Hi, I have a proton waja 1.6, automatic transmission, I drive it since 2009, I'm new and I have a two problems
- Temperature problem: The temperature gauge is an analog. Normally, when I drive, the temperature gauge rises up in to normal level this is in highway driving, but when I drive in city in a traffic jam the temperature gauge suddenly rise up and then go down, this is associated with cooling fan rotation.
-Electrical problem, this happened three times first one when I changed the battery, second one when I went to maintenance workshop, they had to remove the battery cables, the third one is when I installed a sound system also I had to remove the battery cables, the problem is after remove the battery cables for around 15 minutes and connect them again, I tried to drive the car but the engine stopped automatically, this is associated when I shift the gear to D also the RPM gauge show me the engine in 3000 RPM but in fact the engine works as normal in 700 RPM.
midnight73
Posted 03 December 2018 - 03:34 PM
midnight73
Hi, if you could help with pointers on this topic. My Waja - I bought a new starter (RM396) in July 2018 & new battery (RM279.85) in April 2018. Nowadays, I find that the battery dies when I try to start the car after it is unused for a day or two days. Which is rather troublesome .. any suggestions of what the problem could be? I do like the car otherwise. It's still going strong - 180km, 2003 purchase. Thanks, M.
Posted 04 December 2018 - 08:12 AM
  • 71,858 posts
First check whether the battery have problem, meaning cannot keep charge. The battery shop can do a load test. If ok, then need to send to wire man to check if there is a parasitic leak, meaning any thing in your car drawing high current even when the car is off. It can be a light, alarm, the head unit etc. Parasitic leak can drain your battery.....
tpl
Posted 18 September 2023 - 05:57 PM
tpl
    N20 Soul
  • 28,101 posts
wow super experience unker thanks for your help
2012 NMT President
Posted 20 September 2023 - 04:19 PM
  • 71,858 posts
Your car got that problem also?
