Satria Gti - Weird Syndrome
Posted 31 July 2016 - 10:03 PM
During a cool start, engine seems like dying off (like run out of breath), when you step on the accelerator, engine die off immediately. Engine symbol light up. Checked, mentioned oxygen sensor and MAP sensor fault, changed. Change new spark plugs and spark cables too.
Happened recently when I am driving, engine suddenly wanted to die off, same symptoms as above, depress the clutch and let the car slide to road side, step on accelerator, engine died. Disconnected the battery terminals (as means to reset the ecu), connect back and it's become normal.
What could be the issue here?
Please help. Many mechanics are clueless. Can't keep try and error by changing parts.
Posted 01 August 2016 - 06:13 PM
Some mechanic mentioned that there is a power unit near the spark plugs areas that need replacement. Could it be this reason?
Posted 01 August 2016 - 08:54 PM
But you mention disconnect battery terminals and back to normal. Maybe some ECU issues
Posted 03 August 2016 - 08:30 AM
Because if mechanical, disconnect battery should not become ok again......lol
Posted 03 August 2016 - 06:57 PM
Posted 03 August 2016 - 08:27 PM
That is always the problem. I also had a creaking problem when the car is hot but every time go to mechanic no more sound.....lol
