Lubricating The Speedometer Cable ?
Tham58
Posted 28 February 2016 - 05:28 PM
Tham58
  • 67 posts
The speedometer on my 1996 old timer Iswara has been making
a soft ''tak-tak-tak'' clicking sound occasionaly when moving recently,
especially at lower speeds, but seems to be quiet at other times,
higher speeds as well.
The needle itself has been wobbling for some years, again at lower speeds
initially, but now at higher speeds up to 60 or 70 km/h as well.
I've been told this is usually due to the cable lengthening over time,
or maybe lack of lubrication.
As a stop-gap, I've been thinking of disconnecting its socket from the
rear meter panel, and and spraying some silicone onto it.
Might this possibly help ?
Posted 29 February 2016 - 07:36 AM
  • 71,865 posts
No harm trying, but if possible may need a thicker oil
Tham58
Posted 29 February 2016 - 09:12 AM
Tham58
  • 67 posts
Thanks,
I also have a small boittle of thoe  ''Singer'' sewing machine oil,
or a can of  Hardex ''Spray Grease'' ?
Posted 29 February 2016 - 11:30 PM
  • 71,865 posts
It must be liquid form if not how to flow down the cable...... ;)
ShiftVQV6
Posted 03 August 2016 - 07:02 PM
ShiftVQV6
  • 5,659 posts
Gti don't have speedometer cable, am I right?
My speedometer will stuck when cold start the car. After some driving (could range from few meter to few Km), then it back to normal. What issue is that?
Posted 03 August 2016 - 08:20 PM
  • 71,865 posts
Check engine compartment, see got cable from meter to gear box.....
ShiftVQV6
Posted 05 August 2016 - 06:38 PM
ShiftVQV6
  • 5,659 posts
Ok, will check
