Brake Pad Recommendation
Brake Recommend PJ Sound Underbraking Best price
vcys86
Posted 02 February 2016 - 10:37 PM
vcys86
  • 23 posts
Hi everyone here.
I was driving a gen 2 cps and recently there is quite a rough sound (like rocks/steel) from left rear tyre area whenever under medium/hard braking.
I suspect it might be caused by brake pad finishing (since I didn't change for.....6 years+)
Front brake pad changed once few years ago...To something MKT or Trestor Advantage I think...Recommended from here too..
Want to know if any sifu here can recommend some best buck of money for rear brake pad for gen 2 please?
If possible, something that can get in PH Auto PJ?
Posted 03 February 2016 - 08:28 AM
  • 71,857 posts
Trestor Blue Advantage for me is still good. Why not ask PH Auto if they have for your rears too? I manage to get front and back pads for my friend's Wira
mot88
Posted 08 February 2016 - 07:41 PM
mot88
  • 103 posts
Trestor Advanatage (blue color) is the best for below RM 100 pad, not to be mistaken with Trestor Metallic Plus (green packaging). My personal opinion, avoid Metallic Plus as could not stand the lack of bite and changed it even less than 1000 km.
If you are willing to sacrifice performance a bit for less dusting, you also want to try Bendix General CT.
Trestor Advanatage is the same category as Bendix Metal King Titanium but much cheaper.
Some part shops will tell you  Bendix and Trestor are the same, they are not. They only share the same manufacturing plant (FMP) and FMP will manufacture it according to the spec of the brand.
If PH Auto doesn't have. you may try Aik Heng, No. 8, Jalan 8/1E, PJ New town (behind the previous premise of Fook Bee).
Direction as below:
https://www.google.c...163406041376134
Posted 12 February 2016 - 12:10 AM
  • 71,857 posts
To me Bendix Metal King are same as Trestor Metallic Plus only. I actually switch from 3 sets of Bendix from Metal King to Gold to Titanium then only to Trestor Blue Advantage and they bite so much better when cold and still can withstand when hot....
mot88
Posted 20 February 2016 - 11:57 AM
mot88
  • 103 posts
Trestor Metalic Plus is less than RM 50, standard quality (similar to Mintye), where else Bendix MKT is street performance type, product placement same level as Trestor Advanatage.
Nothing beats Trestor Advanatage for below RM 100 street performance pad.
Just realise that TS (thread starter) needed rear brake pad, then it is harder to find and might need the part shop to special order from supplier.
Posted 21 February 2016 - 10:51 AM
  • 71,857 posts
Trestor still have one lower range pads and that is the Deluxe Organic which should be same as Bendix General CT (Ceramic Technology) that is why I put their semi to Bendix semi.....lol. or maybe they match Bendix 4WD range..... ;)
peterwkc
Posted 13 April 2016 - 04:51 PM
peterwkc
  • 89 posts
Interesting topic about brake pad.
