Proton Iriz: Downhill Problem?
proton iriz
LeMustier
Posted 02 November 2015 - 12:20 PM
LeMustier
    4th Gear
  • 4 posts
Hi, so I purchased my Proton Iriz CVT 1.3 Standard exactly two months ago. Had my first service weeks ago.
Driving through the city road is great. Smooth and easy. But there's a downside when driving downhill.
See, I drove my Iriz back to my hometown, it's about 80km from the city. The road that I took has about 50km going uphill and 30km going downhill. What i noticed was that when I drove on a long downhill road, the RPM shoots up to 3, and I'm just at 60km/h. On a steep road, brake is applicable, and the RPM can be tamed because of the brake, but when on a long  (but NOT steep) downhill road, the RPM shoots up. I can use the brake to tame the RPM but it would be ridiculous especially when it's not a steep road and when there are cars behind because it would slow down the car to 50km/h. It made me think twice to cut in line whenever I need to especially cutting an 8-10 wheeler truck who uses the same road because using L gear at top speed would shoot the RPM to 4.
Does this have something to do with the engine braking system? The only solution we have at this moment when driving through a long downhill road is by maintaining at 50km/h, without much pressure on the accelerator.
It made me think that this car is not made for the hillside.
Posted 03 November 2015 - 08:16 AM
  • 71,490 posts
Yes, I think is due to engine braking. My Chery SUV does the same thing but usually on steep downhill, but I do have a particular route that is only slightly sloping downhill, but every time I use that route the engine braking come in and the rpm is higher. Could be that slope has the exact angle that activates the engine braking...
Anyway I will transfer you to Proton section hopefully to get more replies....
LeMustier
Posted 03 November 2015 - 09:47 AM
LeMustier
    4th Gear
  • 4 posts
thanks
rallychamp
Posted 03 November 2015 - 03:37 PM
rallychamp
    hands on habbit
  • 4,669 posts
its step down to assist braking during downhill...
common in mitsubishi based invecs2 and most cvt transmission if not mistaken...
so...do you mean u want lower rpm with higher cruising downhill speed
or want more engine braking?
if u want higher cruising speed during downhill try lightly press the throttle and keep it steady...or just use manual over-ride and keep it high gear...
(NFS Underground)
Posted 03 November 2015 - 08:25 PM
  • 71,490 posts
Yup, he wants lower rpm....
LeMustier
Posted 05 November 2015 - 02:46 PM
LeMustier
    4th Gear
  • 4 posts
Yes, lower RPM...it made my sister's perodua viva looks far superior than my iriz when it comes to downhill performance.
LeMustier
Posted 11 November 2015 - 12:30 PM
LeMustier
    4th Gear
  • 4 posts
Tried the light press and it worked! I just need to practice more and I will get used to it. Thanks!
Posted 12 November 2015 - 07:47 AM
  • 71,490 posts
So lightly press cheats the ECU that you are accelerating...... :D
rallychamp
Posted 12 November 2015 - 07:52 PM
rallychamp
    hands on habbit
  • 4,669 posts
yeap...that trick found since proton campro auto (mitsubishi based invecs2 gearbox)
probably the punch cvt mapping also based on that
(NFS Underground)
