Cefiro A33 Workshops, Aircon Set To 18C
cefiro workshop a33 aircon
neoblitz77
Posted 24 May 2015 - 08:35 PM
neoblitz77
Hi Everyone, Hope everyone doing well :)
I am facing some unusal problems with my cefiro a33 2.0 .. i just got the car but when I have checked earlier it did not had these problems, at least were not visible.
But before going down to the problems, I really want to know good workshops at KL that they can handle A33
Now, to the topic of Problems:
1) Aircon only works when it is set to 18c, anything above that will blow hot air
2) I went to malacca to meet a friend, after 80% of the journey the engine heated up and went towards H .. so i turn off the aircon and wait for a bit and continued, on my way back it heated up again so this time at R&R and checked the water on the water container that goes to the radiator, i did not open the radiator because it could be really hot. So i filled up water and waited for a while and came back to kl. When nearing KL it heated up so i check the container and there was full water.. What else should i check
I think at this point the most important thing for me to find a trust-able mechanic who is specialized in Nissan models like Cefiro/Excimo/Maxima..
Any help will be highly appreciated! Kudos!
Posted 25 May 2015 - 08:13 AM
  • 71,865 posts
1) Probably your air con thermostat have problem
2) Best is to check your radiator in the morning (when cold) whether you have enough water in it. Filling only the expansion bottle is of no use, if your radiator cap is faulty, it will not suck water back into the radiator. If radiator is short of water, then you have to check for leaks.
My mechanic is not a Nissan specialist, but does all sorts of cars, from Kancil to Mercedes and his shop is in Puchong. I have been with him for almost 30 years and he has a Cefiro customer as I have seen this car being serviced there many times. If you want his contacts, I can pm it to you. Main thing like you say, you need some one you can trust
neoblitz77
Posted 25 May 2015 - 04:03 PM
neoblitz77
@vr2turbro, yes i need a trustable person. feel free to PM me please. It would be a great help :D I would even buy u a drink. No kidding :) Also please let me know whether I can mention you to the person or not? Thanks again.
Posted 26 May 2015 - 08:28 PM
  • 71,865 posts
Pm to you already.....
