4g13 Vdo Maf Sensor Cleaning
genocidejc
Posted 14 January 2015 - 01:33 PM
genocidejc
  • 6 posts
Hi Guys,
Is it advisable to clean the MAF sensor since my car is 12 years old now?
I am experiencing higher fuel consumption even after top overhaul.
Thanks in advance
genocidejc
Posted 14 January 2015 - 01:35 PM
genocidejc
  • 6 posts
QUOTE (genocidejc @ Jan 14 2015, 01:33 PM) <{POST_SNAPBACK}>
Hi Guys,
Thanks in advance
I am not sure how to remove the sensor for cleaning though. Anyone willing to advise?
Thanks.
2save
Posted 14 January 2015 - 08:30 PM
2save
  • 14 posts
JUST TAKE STUDY and APPLY the PowerCoding
Thanks in advance
Posted 15 January 2015 - 09:27 AM
  • 71,443 posts
Hi Guys,
Thanks in advance
As far as I know don't touch the MAF sensor. Very sensitive and you can damage it.....
flee
Posted 15 January 2015 - 12:23 PM
flee
  • 7,018 posts
QUOTE (vr2turbo @ Jan 15 2015, 09:27 AM) <{POST_SNAPBACK}>
Yeah, if you are not happy, replace the sensor completely! However, I think you should also check the ECU and other parts of the induction system if fuel consumption is high.
Regards,
Flee
Mikhai
Posted 16 January 2015 - 07:05 AM
Mikhai
  • 294 posts
One thing to check is to make sure correct spark plug is used.
4G13 should be using hotter plug. FC will get bad if changed to cooler one.
rallychamp
Posted 16 January 2015 - 08:35 AM
rallychamp
    hands on habbit
  • 4,669 posts
vdo car nor MAF sensor....its MAP sensor......
how to check? easy....
MAF is the big sensor located beside big airbox.....
MAP sensor is small black sensor located on the intake manifold at around fuel injector location
only MAF need cleaning because it always subjected to airflow right behind air filter...
MAP sensor just a sensor with small hole detecting vaccum (or to be exact Manifold Absalute Pressure) hence the name...and didnt geet dirty because it just got small opening....unlike MAF sensor basically a screen filter across the intake pipe...
(NFS Underground)
Posted 16 January 2015 - 08:46 AM
  • 71,443 posts
QUOTE (rallychamp @ Jan 16 2015, 08:35 AM) <{POST_SNAPBACK}>
But MAF also a few types, right? Mine is hot wire or something like that. Mechanic told me not to attempt to clean as it is very sensitive and can be easily damaged.... smile_blackeye.gif
goohtj
Posted 17 January 2015 - 09:18 AM
goohtj
  • 104 posts
QUOTE (vr2turbo @ Jan 16 2015, 08:46 AM) <{POST_SNAPBACK}>
yes. very very fragile. just spray softly with electronic cleaner if you really want to try. cost me rm450 for this failed diy.
its as soft as a burned match stick.
Posted 17 January 2015 - 12:13 PM
  • 71,443 posts
QUOTE (goohtj @ Jan 17 2015, 09:18 AM) <{POST_SNAPBACK}>
