Ron 97 Incompatible
magiclife
Posted 20 November 2014 - 10:46 AM
magiclife
    3rd Gear
  • 3 posts
Sifu Sifu here, wanna ask a question. If your car having minimum requirement to use RON 95, would you have a problem to use RON 97, RON98 & above?
thanks for the feedback
Posted 21 November 2014 - 08:52 AM
  • 71,853 posts
QUOTE (magiclife @ Nov 20 2014, 10:46 AM) <{POST_SNAPBACK}>
No problem, only you will be paying more for your fuel.
Cars requiring lower Ron can running on higher Ron fuel, but if your car requires Higher Ron fuel you cannot run it with the lower Ron fuel. Will have knocking and in long run will damage your car.... smile_tongue.gif
yhwoo16
Posted 27 February 2015 - 03:51 PM
yhwoo16
  • 7 posts
Higher octane fuels are used for vehicles with higher compression rations. A higher compression ratio gives an engine a higher horsepower per engine weight than one with a lower compression ratio — making the engine high performance.
RON97 is recommended for drivers of vehicles with an engine capacity above 2,500cc.
Posted 28 February 2015 - 09:39 PM
  • 71,853 posts
QUOTE (yhwoo16 @ Feb 27 2015, 03:51 PM) <{POST_SNAPBACK}>
First part is correct for higher compression engine, but not all high cc cars comes with higher compression, so 2500cc not necessary need to use Ron 97.
More over with new technology like GDi and even Mazda new skyactiv engine with high compression are tuned to use Ron 95 only... smile_tongue.gif
Mikhai
Posted 01 March 2015 - 09:26 PM
Mikhai
  • 294 posts
Fifth Gear did a very good comparison on the RON. The different is really insignificant.
Posted 02 March 2015 - 08:36 AM
  • 71,853 posts
QUOTE (Mikhai @ Mar 1 2015, 09:26 PM) <{POST_SNAPBACK}>
Second video shows got difference if driving performance engine. Modern engine the ECU can detect and adjust to run on the fuel but with lower power. Old school engine like mine the ECU cannot detect so running on Ron95 it will knock, unless manual de-tune. So if need to de-tune then no point mah! might as well drive non performance car.....hahaha smile_big.gif
justdoit
Posted 17 March 2015 - 02:17 PM
justdoit
  • 227 posts
But my old Wira 1.5 requires Ron 97 as stated in the booklet.???
moon
Posted 18 March 2015 - 07:48 AM
  • 71,853 posts
QUOTE (justdoit @ Mar 17 2015, 02:17 PM) <{POST_SNAPBACK}>
Are you sure? So far all my friend running on Ron95 without problems..... smile_tongue.gif
justdoit
Posted 18 March 2015 - 04:16 PM
justdoit
  • 227 posts
QUOTE (vr2turbo @ Mar 18 2015, 07:48 AM) <{POST_SNAPBACK}>
Yes, but can use 95, no problem
moon
Posted 19 March 2015 - 09:13 AM
  • 71,853 posts
QUOTE (justdoit @ Mar 18 2015, 04:16 PM) <{POST_SNAPBACK}>
