Proton Iswara Uk Spec Engine Die Off During Drives .
iswaracare
Posted 31 October 2014 - 08:05 AM
iswaracare
Help!
Desperately needed some help from all of u experience guys here.
My car Proton Care UK spec .
1993 Auto transmission .
Fuel injection .
Problems ,
Die off during driving with indicator CHECK ENGINE !
Went all the troubles and time on one mechanic who change fuel pump
Fuel pump delay
Overhaul top pistons and the same thing still happened.
Symptoms. 1. Dragging starts when engine is cold
2. Die off during drives after engine is hot
3. After 1st die off, cannot manage to starts unless waiting for at least 5 minutes.
4. Continuing die off after that
Can't change car since I'm in financial difficulties at this moment. Hope all u Taiko will help me on this matter.
Thank you.
Posted 31 October 2014 - 06:24 PM
  • 71,864 posts
QUOTE (iswaracare @ Oct 31 2014, 08:05 AM) <{POST_SNAPBACK}>
Help!
Fuel injection .
Problems ,
Fuel pump delay
Thank you.
Check engine light comes on, please send to mechanic to do diagnostics check. Not just simply Change this and that.... smile_blackeye.gif
Gunnerzz
Posted 01 November 2014 - 06:42 PM
Gunnerzz
  • 3,102 posts
QUOTE (vr2turbo @ Oct 31 2014, 06:24 PM) <{POST_SNAPBACK}>
Yup.
However,older ecu sometimes does not pin point the exact fault.
have to find expech to study the readings.
in my opiniom once studied properly,it could lead to o2 sensor failure.
khskeet
Posted 14 December 2014 - 06:05 PM
khskeet
  • 314 posts
QUOTE (Gunnerzz @ Nov 1 2014, 06:42 PM) <{POST_SNAPBACK}>
Yup.
Iswara normally problem are easy to solved. Check the error first the look again what is the problem
