I changed a set of GAB SA Series Sport Absorbers today and the ride together with its handling on the road are great. I must say these are really high quality absorbers and worth for money.
Auto Valve Control Stability - AVCS.
AVCS is the latest result of our constant R&D effort. With GAB AVCS you can now feel the difference on uneven road, bumpy road, pothole, high-speed corners and highways. The damping and rebound force is automatically tuned by AVCS to suit all road conditions. AVCS is an internal system that adjusts the stiffness of the suspension. It uses multiple layer valve spring to sense the road condition and automatically reduces or increase damping force according to the road condition and your driving style. The result is superior handling and maximum comfort on all road condition without having to manually tune or adjust the absorber.
Satisfaction guaranteed with handling improvement & comfort
SA series is well balance heavy-duty sport absorber, Auto Valve Control Stability (AVCS) has the ability to be more effectively absorb the impact and vibration from uneven road condition, and provide maximum grip and traction. Superb handling, high stability and comfortable are SA series successful point.
Compatible with all type spring.
Unlike standard shock absorber, SA series sport absorber can compatible with standard spring or sport-lowered spring with out sacrificing ride comfort and absorber’s life span.
Auto Valve Control Stability (AVCS), high-pressure nitrogen gas fill in, strengthen absorber structure, double up life span.
Gab Sa Series Sport Absorbers Are Perfect For Proton Persona
comanche91
, Apr 19 2014 07:15 PM, No replies to this topic
Posted 19 April 2014 - 07:15 PM
If you make a habit of buying things you do not need, you will soon be selling things you do - Filipino Proverb
