K&N Pro Series Premium Oil Filters
â–º Newly Engineered High Quality Oil Filters.
â–º High-Flow / Low Restriction designed to improve Engine Performance.
â–º Outstanding Filtration and Engine Protection.
â–º Strong Sidewall Canisters for Higher Burst Strengths.
â–º Works with all grades of synthetic, conventional and blended motor oils.
Product Specifications:
Product Style: Oil Filters
Anti Drain Back Valve: Yes
Bypass Valve: Yes
Filter Material: High Flow Premium Media
Gasket Material: Nitrile Rubber
Height: 3.75 in (95 mm)
Outside Diameter: 2.688 in (68 mm)
PSI Relief Valve: 11-17
Removal Nut: No
Style: Canister
Thread Specification: M20 x 1.5
Weight: 0.5 lb (0.23 kg)
If you make a habit of buying things you do not need, you will soon be selling things you do - Filipino Proverb
