So it was obvious I didn't have the right stuff to do the job. So I dropped by Osren to see what Henry (bro Hitachi) had in his shop to make my life easier. So he suggested Jeans pad (when you google its called denim pad) & Osren P40 combo with LC Twisted wool & P40 to finish off. So he did a test panel on my car with those combos and it worked. What he pointed out and then I realized also was that the clear coat was hard that with the Jeans pad & P40 combo, it doesn't haze the paint. Actually the finish was pretty good standing 1 feet away and is passable as a daily driver. Only under closer inspection you could see a few holograms.
So back to the house I went a started work on the car. So this is what I noticed, I forgot to mention that the machine used was an RB:
1. Henry said that the jeans pad works better when primed properly and you should always have it primed and not fully clean the pad like we normally do with foam pads. Very true, it took some priming of the jeams pad to get it up and runiing properly. Once primed properly and a few passes was made on the panels, its was great to use. When new, it tends to be grabby, but once primed properly its nice and smooth to use.
2. P40 is really aggressive and you can hear the grittiness of it when you spread it on the paint.
3. With the Jeans + P40 combo, you need to get the speed and pressure right, if not you can have hazing and some slight holograms and the occasional marring/swirl here and there. But if you do it properly, the finish is surprisingly good with no hazing and little marring.
4. Finish off with LC Twisted wool pad & P40 will give you a 95-98%++ finish. Goodness I cannot believe you use this combo as a finishing step when normally you would use it as a sanding mark removal combo, that gives you an idea of how hard the paint it. One pass of this is enough to finish off the paint unless you missed some spots.
All the water marks are on the boot, roof and bonnet. I didn't bother to remove all the water marks as some of them are so deep that if you level them off you would have little to no clear left. So I just did whatever I could. Since its a daily driver, it'll do. So here are some pics. You can really see its got great, clear sharp reflections with little orange peel. You can see the sharp text reflections of the bottle and rough textures of the white pillar reflecting off the paint. The lines of the pillars are pretty straight as well.
Water Mark which is deep and I didn't remove
