Unremovable Stain On White Paint
Posted 03 October 2013 - 10:54 AM
I have this stain from while idle for about 1 mth in parking lot.
It's a hardened substance resulting from concrete ceiling leak.
I tried using non-abrasive polish but it doesn't work.
Any suggestion?
Thanks a lot
Posted 03 October 2013 - 03:13 PM
If it doesn't work try a compound like M101.
If still don't work, try wet sanding.
If still don't work, change car
Posted 03 October 2013 - 06:28 PM
Yup, try something more aggressive, but start from the least aggressive and move upwards to most aggressive products
Posted 03 October 2013 - 07:46 PM
You might want to try something acidic based since its those concrete water scale marks. Can try Forma hero rain spot remover for glass. Its an acid based product. Makes sure car is wet and cloth is wet. Used with caution and rinse well. Use in a small spot first.
Not sure if it'll work but can try lah. If it doesn't work then have to use abrasive method as mentioned above worse case respay area.
Posted 04 October 2013 - 08:20 AM
If not mistaken, remember those acid base glass cleaner did mention not to get them on paint, right?
Posted 04 October 2013 - 08:29 AM
Will try out one after another. Probably will also try out those abrasive polish.
The stain was thick that i needed a sand paper to reduce the thickness.
Regards
Yang
Posted 04 October 2013 - 08:31 AM
LOL, i like your statement "If still don't work, change car "
Posted 04 October 2013 - 10:01 AM
Many new car models launched in 2013
Regards
Yang
try AG SRP. It's close to a pure polish. However, if it's harden, then wet sanding would be the next choice.
Posted 05 October 2013 - 10:49 AM
Any suggestion?
Thanks a lot
Im pretty certain the top surface of clearcoat (if its clearcoated) has been damaged by the stuff
from ceiling. It's probably not a dirty stain.
During construction, caustic lime (white powder) is often mixed with water, resulting in a boiling, highly caustic solution.
When theres any leakage within ceiling, that stuff gets moist and is "reactivated". Highly caustic.
Always look up at basement ceiling...if u see white goo dripping down, park elsewhere.
If i were u, id do 1500g sanding. If that doesnt solve it, you'd hv to respray the bonnet.
