My car is a 2001 Citroen Xsara 1.6A. For the last few months, I have been experiencing problem with the air-cond. Whenever the car is not moving either due to jam at the causeway to Singapore or long queue on a congested highway, my engine will suddenly develop a 'shiver' which will reduce the power of the car greatly. If I step on the accelerator, the car seems to 'drag'. I will have to switch off the engine and re-start after few seconds. This time, I will have to switch off the air-cond as well so that the engine will work normally. Otherwise, the 'shiver' will start again. I am trying to think if there is a link to the alternator or battery. I observed that once I am home from work, the engine fans will continue running to cool down the engine even after I've switched off for at least 5 minutes or so. I am not sure if this draws away the power from the alternator or battery causing the effect on the air-cond? Any advice, anyone?
Air-cond, Alternator, Battery Or Engine Problem?
Jaguar69
, Jul 04 2013 11:00 PM, 1 reply to this topic
Posted 10 July 2013 - 08:47 AM
QUOTE (Jaguar69 @ Jul 4 2013, 11:00 PM) <{POST_SNAPBACK}>
Did you use proper radiator coolant?
I think it is due to engine heat problem.
Once, the engine heat reach certain level, the ECU will lower down the engine RPM. so, you will feel some shiver. However, if your radiator cooling system work well, you should not have this problem with your air-con on.
First thing to do, use proper radiotor coolant. The best coolant is the original Citroen coolant that cost about RM2x ~ RM3x per 2 litters. This is pre-mix coolant, which means you do not need to mix with additional water. Fully use this citroen coolant. This coolant got much higher boring temperature.
For typical citroen/peugeot car engine temperature is around 89C and higher temperature during running in high speed.
If you using normal water in your radiator, the water will start boring when the engine heat up to 92C and it will cause less efficient on cooling the engine temperature.
If the problem still happen after you fully use citroen coolant, then you should send to workshop check for the thermostat.
camus
