June 2012 Group Order
Posted 25 May 2012 - 11:04 AM
Order Collection - 16 June 2012
1. Engine Oil Package
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
Recommended change interval - 5,000km ~ 7,500km depending on drive condition.
2. ATF Oil Package
i. ATF Oil FUCHS Titan 3353 (as specified in spec)
- 5 litre/container (sufficient for 1 drain-off) - $250
- 2 X 5 litre/bottle (If full flushing, require 9.5 litre) - $500
ii. Mayle Germany ATF Filter with Gasket - 1pcs - $100
Recommended change interval - 40,000~60,000 km depending on drive condition.
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM400
4. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rear Shock Stopper - RM75/each = RM150
6. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
7. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
8. Transmission Mounting - $130
9. 1 set Engine Mounting (2pcs) - $130 X 2 = $260
10. Vacuum Modulator - RM250 each X 2 = RM500
11. OEM Vemo Coupling Fan Clutch = RM250
12. Coolant Sensor - $75
13. Air Filter (OEM - Made in Korea) - RM60
14. Diesel Filter (OEM - Made in Korea) - RM180
15. Water Separator (OEM - Made in Korea) - RM250
16. Bendix 4WD Brake Pad (Front & Rear) - RM290
17. Contitech Fan Belt (2257) from Germany - RM80
18. Aircon Cabin Filter (Korea OEM) - RM60 / set
19. Crank POS Sensor Sensor - RM150
20. Cam Sensor - RM170
21. Tie Rod & Rod End - RM190 / set X 2 side = RM380
22. Tailgate Gas Struts Lifter (Window) - Local brand = RM90 / piece
23. Gas Struts Lifter (front bonnet) - Genuine Original = RM 130 / piece
24. Power Window Motor = RM190
25. Rear Brake Shoe - Original = RM 450 / set of left and right
26. Glow Plug - Original - RM90 per piece
27. Thermostat & Gasket - RM130 / set
28. Front Brake Disc (Left & Right) Original - RM650/set
29. Rear Brake Disc (Left & Right) Original - RM600/set
Order List
1. allan69 - RM510 - PAID
2. WQP8221 - RM150 - Canceled (No response)
5. Rear Shock Stopper - RM75/each X 2 = RM150
3. Lu18 - RM180 - Out of Stock - Cancel Order. Payment added to VS.
4. Billkong - RM1040
2. ATF Oil Package - RM350
14. Diesel Filter (OEM - Made in Korea) - RM180 (is this suitable for Rex2? if yes I take one.) - Paid extra RM100
19. Contitech 2255 (Made in Germany) - RM150 - Unpaid
5. teps168 - RM790 - PAID
Water separator - RM250
Diesel Filter (OEM - Made in Korea) - RM180 - Pending top up RM100
6. nas75rex - RM240 - PAID
14. Diesel Filter (OEM - Made in Korea) - RM180 - Canceled
7. jns6888 - RM780 - PAID
21. Tie Rod & Rod End - RM190 X 2 side = RM380
8. fhfoomelaka - RM340 - Paid RM280
1. Engine Oil Package - RM280
9. eddredd - RM100 (Canceled - No Response)
- 2pcs rx290 Oil filter - RM25 X 2 = RM50
- 1pc rx290 air filter - RM50
10. wyliew - RM580 - Paid
1. ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
2. ii. Mayle Germany ATF Filter with Gasket - 1pcs - $100
11. Sofian - RM240 - PAID
12. Phoong2323 - RM350
Total Order = RM4,520
Order Paid = RM3,360
Bros who wish to make their order, please post your list here and payment instruction will be PM to you.
Posted 25 May 2012 - 11:22 AM
2. ATF Oil Package
Order List
1.
Total Order =
Order Paid =
Bro Wilson,
I will need the following:-
Would it be possible to buy just 1x Vaccum Modulator? I am considerng EGR delete. If not, please proceed.
Posted 25 May 2012 - 04:47 PM
Yes, can just buy 1 pc Vacuum Modulator if you blanking off EGR. For those who running EGR, better to change both together.
Posted 25 May 2012 - 11:06 PM
hi bro,
went to melaka yesterday and neonlee updated new v3.powermap and previously blanked-off egr-deleted and took out 1 vacuum modulator. According to neonlee, the v3.powermap would check also 2 units of vacuum-modulators are working or not. Since I got only 1 vacuum modulator left after blanking off egr, yellow checklight appears after new remapping. So neonlee remodified v3.powermap to prevent checking of vacuum-modulators. So now v3.powermap got: a) vacuum-modulator checking and
So bro, while the vacuum-modulator checking version is good since it will monitor the performance of the vacuum-modulators, I am "thinking" whether I should put back the "missing" unit? What's your opinion?
phoong
Posted 26 May 2012 - 12:33 AM
phoong
Right, it is good to keep the check for VM, so if you have extra VM, better to put it back instead of waiting for it to rot in your toolbox.
Posted 26 May 2012 - 12:56 AM
ok, I will put it back during this Sunday DIY. Thanks....
Posted 27 May 2012 - 06:42 PM
Posted 28 May 2012 - 05:46 PM
Added your order
Posted 29 May 2012 - 03:38 PM
bro, ATF Oil Package got stock already? Can I buy Dirko?
Posted 29 May 2012 - 06:06 PM
Will check and get back to you. In KCH now with limited internet access, so not so convenient.
