Help: Mistakenly Put Petrol Into My Dmax
Posted 14 April 2012 - 10:22 AM
  • 71,855 posts
QUOTE (LanGanu007 @ Apr 13 2012, 02:32 AM) <{POST_SNAPBACK}>
I thought you would say help to lubricate upper cylinder......
spirit36
Posted 15 April 2012 - 08:27 AM
spirit36
  • 1,862 posts
QUOTE (reddmax @ Apr 9 2012, 12:00 AM) <{POST_SNAPBACK}>
What should i do... I mistakenly pump around 4 litter petrol into my dmax car. My friend say its will be ok if only 4 litter petrol if u put a lot disel coz i will mix. Then i put another RM40 disel and star the enjin. Until now i have been use it for 20km. No problem and it still run.
My Q.. Should i go to workshop to 'cuci tangki' or just use it. Its there any problem to my enjin or fuel pump?
Thanks and sory for my poor english.
Your ride should be OK now since its already few days without any engine rattling,,, (touch wood)
however, like some of the bros here recommended, use injector cleaner and change your fuel filter...
I would say for now use injector cleaner with every full tank for the next 3 full tanks.
Then u can do it at every 3k-5k mileage....
I use Morey's and another brand which I can't remember, but the point here to use these injector cleaner...nothing to lose but gain except slight cost increase...
br1
Posted 15 April 2012 - 10:20 AM
br1
  • 2,825 posts
QUOTE (spirit36 @ Apr 15 2012, 08:27 AM) <{POST_SNAPBACK}>
I dont use injector cleaner every 3 or 5k km, but like bro Tazz recommend occassionaly hit at 4000 - 4500k rpm drive clean better.
Posted 15 April 2012 - 04:51 PM
  • 71,855 posts
QUOTE (br1 @ Apr 15 2012, 10:20 AM) <{POST_SNAPBACK}>
macques
Posted 24 April 2012 - 12:01 AM
macques
    Driver
  • 38 posts
Bro, you don't have to use injector cleaner. This is not gasoline injectors. Diesel injector can be service, so try. It to add so many additives into your fuel system or later it will break your fuel system. Try to change your diesel filter often in order to maintain good fuel system. Common rail pressure can generate up to 1800 bar, so don't spoil your system
