i using PC with asus m/b
i success to format the hdd, but always repeat format step
actually in my experience, after format, PC will restart, and install XP
my problem is the format step always repeat, cannot install xp
in bios, not problem, can detect HDD
also had change 2-3 new hdd, still same problem....
had unplug battery... still same
what can i do.....
Always Repeat Format Step
cboys00
, Apr 05 2012 09:32 PM, 3 replies to this topic
Posted 06 April 2012 - 11:01 AM
always pop-up this message
boot from atapi cd-rom no emulation
no instruction to boot from cd, press any key....why, how to solve
Posted 18 April 2012 - 11:42 AM
QUOTE (cboys00 @ Apr 5 2012, 09:32 PM) <{POST_SNAPBACK}>
what can i do.....
what can i do.....
Fren,
How u format the hdd?
1)Put your XP/Win7 installation boot CD/DVD into optical drive to let it boot, then you can select format NTFS in selected partition.
2)Upon reboot after completed format, please do not select to boot from optical drive anymore. Or maybe you can change your boot option priority from the CMOS. Else, everytime also boot fresh, of coz it'll ask you to format. After 1st format, your hdd already loaded with basic boot OS. It'll continue to install and copy all necessary files automatically unless prompt u for regional/date/time/network settings.
Posted 18 April 2012 - 11:46 AM
QUOTE (cboys00 @ Apr 6 2012, 11:01 AM) <{POST_SNAPBACK}>
THis shown in Windows environment or in DOS prompt?
If in Windows, check your Atapi CD-Rom driver, but normally most drive sure compatible unless you use a very very old CD-Rom drive, or already got problem.
If in DOS prompt, just press any key to boot lah... or maybe you've inserted non-bootable disc?
