My OEM tyres are due for a change soon. I'm currently at 20k km and I expect to change the tyres at between 30k to 35k km.
I just discovered Contiseal tyres. Apparently they are not as expensive as run-flats and are standard fitment in higher-end VWs sold in Malaysia.
Does anyone have experience with Contiseal?
Replacement Tyres For S-max
Kevin
, Mar 12 2012 11:09 PM, 6 replies to this topic
Posted 13 March 2012 - 06:59 AM
QUOTE (Kevin @ Mar 12 2012, 11:09 PM) <{POST_SNAPBACK}>
the smax uses run flat tyres??
Posted 13 March 2012 - 05:29 PM
QUOTE (droll @ Mar 13 2012, 06:59 AM) <{POST_SNAPBACK}>
No, it doesn't. The S-Max comes with normal tyres with a tyre sealing and inflation kit supplied.
Posted 13 March 2012 - 09:47 PM
QUOTE (Kevin @ Mar 13 2012, 05:29 PM) <{POST_SNAPBACK}>
then i suggest u keep the radial tyres setup. run flats on suspension setup that wasn't designed for run flats will ruin the ride.
Posted 14 March 2012 - 03:25 PM
QUOTE (droll @ Mar 13 2012, 09:47 PM) <{POST_SNAPBACK}>
That's why I'm considering Contiseal.
Posted 10 January 2013 - 04:38 PM
Hi Kevin,
Is your S-Max using Goodyear Excellence 225/50 R17?
One SDAC Ford salesman told me the Ford S-Max is using Run-Flat tyres.....now I'm confused.
How to check whether it is run-flat?
Thanks
Posted 10 February 2013 - 12:00 PM
QUOTE (erymanthus @ Jan 10 2013, 04:38 PM) <{POST_SNAPBACK}>
Hi Kevin,
Thanks
Thanks
Run flats must have tpms as an accesory. Otherwise, one does not know when the tyre is running on flat
My current smax is running on michelin premacy hp.
Mr757
