2011 Ssangyong Actyon 2.0 Owner Reviews
#31
Posted 02 March 2012 - 11:38 PM
Today, I drove from ipoh to Shah Alam in heavy rain most of the way. My Actyon feels planted to the road and not a moment of panic. But FC now average 10l/100km for mainly highway driving. Seems to have gone up slightly since the update to the map from around 9.7 or 9.8. Tomorrow going for another service as it is 5000km since the last. Unfortunately have to bring it from Ipoh to KL to do it as Ipoh no authorized SC. Planning to change ATF again as Stanley at USJ claims he has the Fuchs 3292 ATF. Don't feel comfortable with the present ATF from CS 20,000 km ago for good reason but cannot broadcast here.
Hopefully that little lumpiness at around 50 when slowing down will be cured.
#32
Posted 03 March 2012 - 04:34 PM
#33
Posted 03 March 2012 - 11:57 PM
Hi bro, your ride is really clocking milleage fast. So is Stanley got the right ATF? What diesel u r using? Seems like not as bad as we think. I m also going there soon for 20k service. Try to troubleshoot the vibration.
tazztham
#34
Posted 04 March 2012 - 06:43 PM
using mainly Caltex or Petronas diesel. And every service a treat of Bluechem common rail cleaner. Not a speck of water or dirt! But I always try to chose the more popular stations and avoid early morning refueling and stations in low lying areas which may get flooded.
#35
Posted 05 March 2012 - 12:18 PM
Did you check with Stanley if other owners also complained about the gb jerking and high FC, also if they do carry the required ATF?
#36
Posted 05 March 2012 - 08:14 PM
Nope. As for the stock of ATF, I did not see it at his place but on the phone earlier he said he has stock.
The other problem with the high FC is the need to refuel every 450 km or so. The gear shift is not that bad anymore. The 520d also don't have a perfect shift. But 520d refuel only every 900km or so though for about RM20 more.
#37
Posted 07 March 2012 - 09:48 PM
The gearshift is quite acceptable. Even the 520d gearshift has a slight lumpiness at times. So only major issue is th FC now.
Power window now works well after the lug job at Stanley's.
#38
Posted 07 March 2012 - 10:02 PM
Maybe you can switch car with your brother to test drive for several days to see if the FC is related to driver or purely on the engine performance difference.
#39
Posted 07 March 2012 - 10:21 PM
No need la. Before update his FC was higher than mine. Also when I drove to and from K.l., I was so gentle keeping to the speed limit most times with auto cruise on and in ECO mode. Still can't bring the average FC below 10L/100km. Now it is showing 10.4. Before update mine often come down to around 9.7. Since update not seen this reading.
#40
Posted 07 March 2012 - 10:24 PM
bro kh, could the meter corrupted !!! try calculate manual.
