Order & Payment Deadline - CLOSE
Order Collection - 24 Sept 2011
1. Engine Oil Package
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
Recommended change interval - 5,000km ~ 7,500km depending on drive condition.
2. ATF Oil Package
i. ATF Oil FUCHS Titan 3353 (as specified in spec)
- 5 litre/container (sufficient for 1 drain-off) - $250
- 2 X 5 litre/bottle (If full flushing, require 9.5 litre) - $450
ii. Malee Germany ATF Filter with Gasket - 1pcs - $100
Recommended change interval - 40,000~60,000 km depending on drive condition.
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM400
4. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rear Shock Stopper - RM75/each = RM150
6. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
7. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
8. Transmission Mounting - $130
9. 1 set Engine Mounting (2pcs) - $130 X 2 = $260
10. Vacuum Modulator - RM250 each X 2 = RM500
11. OEM Vemo Coupling Fan Clutch = RM250
12. Coolant Sensor - $75
13. Air Filter (OEM - Made in Korea) - RM60
14. Diesel Filter (OEM - Made in Korea) - RM180
15. Water Seperator (OEM - Made in Korea) - RM250
16. Bendix 4WD Brake Pad (Front & Rear) - RM290
17. Contitech Fan Belt (2257) from Germany - RM80
18. Aircon Cabin Filter (Korea OEM) - RM50
19. Crank POS Sensor Sensor - RM150
20. Cam Sensor - RM170
21. Tie Rod & Rod End - RM190 / set X 2 side = RM380
Order List
1. r3xt0n - RM660
i. Engine Oil Package - RM280
ii. Tie Rod & Rod End - RM380
2. Neonlee - RM250
i. ATF Oil 5 litre - RM250
3. Jail0s - RM785
i. Engine oil package - RM280
ii. Transmission mounting - RM130
iii. Crank & cam sensor 150 + 170 = RM320
iv. TuffOil - RM55
4. Razopower - RM320
i. Crank POS Sensor Sensor - RM150
ii. Cam Sensor - RM170
5. Kenny_4744 - RM630
1 i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
6. Sampen - RM250
7. Sofian - RM760
i. Aircon Cabin Filter - RM50
ii. Crank POS Sensor - RM150
iii. Cam Sensor - RM170
iv. Engine Oil Package - RM280
v. Tufoil X 2 - RM110
8.
9.
10.
Total Order = RM3,665
Payment Paid =
Payment Paid =
Bros who wish to make their order, please post your list here and payment instruction will be PM to you.
Sept 2011 Group Order
r3xt0n
, Sep 06 2011 10:16 AM, 5 replies to this topic
Posted 06 September 2011 - 11:33 AM
QUOTE (r3xt0n @ Sep 6 2011, 10:16 AM) <{POST_SNAPBACK}>
Order & Payment Deadline - 19 Sept 2011
2. ATF Oil Package
17. Contitech Fan Belt (2257) - RM70
21. Transmission Speed Sensor - RM150
22. Tie Rod & Rod End - RM190 / set X 2 side = RM380
Order List
1. r3xt0n - RM660
2.
3.
4.
5.
6.
7.
8.
9.
10.
Total Order = RM660
Payment Paid =
2. ATF Oil Package
Order List
1. r3xt0n - RM660
2.
3.
4.
5.
6.
7.
8.
9.
10.
Total Order = RM660
Payment Paid =
5 liter - ATF Oil
Posted 06 September 2011 - 12:11 PM
QUOTE (neonlee @ Sep 6 2011, 11:33 AM) <{POST_SNAPBACK}>
5 liter - ATF Oil
No need ATF Filter & Gasket?
Posted 06 September 2011 - 12:16 PM
QUOTE (r3xt0n @ Sep 6 2011, 12:11 PM) <{POST_SNAPBACK}>
no need, as need to drain off only...
Posted 06 September 2011 - 11:12 PM
My order
Engine oil package 280
Transmission mounting 130
Crank & cam sensor 150 + 170 = 320
TuffOil 55
Total : rm785.00
TuffOil 55
Total : rm785.00
Posted 07 September 2011 - 12:26 AM
QUOTE (jail0s @ Sep 6 2011, 11:12 PM) <{POST_SNAPBACK}>
My order
TuffOil 55
Total : rm785.00
TuffOil 55
Total : rm785.00
Added your order, will PM you payment instruction shortly.
