CHANGE THE FUEL FILTER AND RESET THE ERRORS
Rexton 270xdi - Engine Check Light
unser7272
, Nov 04 2010 07:31 PM, 13 replies to this topic
Posted 27 January 2011 - 11:50 AM
QUOTE (christos @ Jan 27 2011, 02:43 AM) <{POST_SNAPBACK}>
Hi Christos,
Are you a Rexton owner too? If yes, why not intro yourselves at http://forum.autowor...showtopic=97277 to be added to our Rextonian List?
You are welcome to interact and share with all the Rexton owners here.
Posted 13 February 2011 - 08:08 PM
hello, i am a new driver of a 2004 Rexton 270 XDI and don't know how to diagnose check engine light. Is there a proper way to do this like this one http://www.automd.co...problem_id=1754 ? if anyone here has a more detailed resource. I am having a hard time understanding car stuffs.
Posted 13 February 2011 - 08:34 PM
QUOTE (jackj @ Feb 13 2011, 08:08 PM) <{POST_SNAPBACK}>
Hi jackj , welcome to rextonhub.
http://forum.autowor...h...20&start=20 ( can self introduce here )
could you tell us when check engine light happen, is it on and off or permanent? some can be remove by switch-off the engine , turn-on about 5 second until check engine light dissapear..then start.
if it won't go off , then must scan using scan-100 or other scanner that have compatible program/reading. it could be done at service center ( they charge about rm120 in SC juru) or any outside workshop that has the device( usually at half the price).
some of simple problem
it could be temporary - coolant sensor, won't effect the drivability ,,lost traction in slope also temporary..lost turbo pressure-disconnected hose -all just restart would do.
ssps sensor or speed sensor power steering , can be driven but without power steering assist ( ssps light will illuminate too )
water separator light - permanent - replace water separator then reset error code
if it check engine light illuminate permanent and the car in limp mode - the ecu will prevent the car speed above 80km/h usually just stay in 4th...it could be diesel filter need replacement , injector, loss of pressure in fuel line or pump or others that can be check using scan 100.
cheers
NIK
