Saga Blm
dabdab
Posted 25 September 2010 - 11:35 PM
dabdab
  • 470 posts
QUOTE (vr2turbo @ Sep 25 2010, 10:42 PM) <{POST_SNAPBACK}>
Potong springs, whole spring tension is changed.
Bakar the springs, the metal tension is changed. As far as I know both also wrong.
I have tried even a third method, by lowering the holding point of the springs on the shocks. This means I grind away the welding, lower the holding point and weld back again. This way the car will get lower also, but bad mistake. Since this will widen the space of the springs, the springs are not compressed and loses it rigid strength. Will bottom out and rebound also not good. Use it for about a month and then reposition back to original...... smile_wink.gif
yeah, this creative mod will insecure the spring position in its seat. imagine during hard cornering, due to body roll, the inner side car body lifted and suddenly the spring popped out from its seat. - could lead to mishap.
#62
Posted 26 September 2010 - 08:40 PM
  • 71,471 posts
QUOTE (dabdab @ Sep 25 2010, 11:35 PM) <{POST_SNAPBACK}>
#63
dabdab
Posted 29 September 2010 - 10:22 PM
dabdab
  • 470 posts
QUOTE (vr2turbo @ Sep 26 2010, 08:40 PM) <{POST_SNAPBACK}>
yeah, scary
to blm owner any of you facing with a defect of canister purge valve which is located top near the iafm manifold, the symptom is like a louder tappet sound. it will be replaced under warranty
#64
Posted 30 September 2010 - 11:07 AM
  • 71,471 posts
QUOTE (dabdab @ Sep 29 2010, 10:22 PM) <{POST_SNAPBACK}>
yeah, scary
Is that a common problem??
#65
dabdab
Posted 30 September 2010 - 09:08 PM
dabdab
  • 470 posts
QUOTE (vr2turbo @ Sep 30 2010, 11:07 AM) <{POST_SNAPBACK}>
not sure, but it does happen to me,
thats why im asking
#66
Posted 30 September 2010 - 09:10 PM
  • 71,471 posts
QUOTE (dabdab @ Sep 30 2010, 09:08 PM) <{POST_SNAPBACK}>
thats why im asking
How about bro. Gunnerzz??
#67
Gunnerzz
Posted 01 October 2010 - 03:15 PM
Gunnerzz
  • 3,102 posts
QUOTE (vr2turbo @ Sep 30 2010, 09:10 PM) <{POST_SNAPBACK}>
My tappet sound is as usual.
In fact i think its quieter than my sis Neo CPS.
Will confirm it tonight as i havent listen to my engine for some time now.
My car oso dirty...Too busy with work.
#68
dabdab
Posted 05 October 2010 - 09:39 PM
dabdab
  • 470 posts
QUOTE (Gunnerzz @ Oct 1 2010, 03:15 PM) <{POST_SNAPBACK}>
this is the EVAC valve or canister purge valve having a tapping sound due to defect. it has nothing to do with valve tappet, but it sounds like one. it is used by control to recirculate fuel vapor in the tank back into intake manifold so non will be released to the atmosphere.
i paste the image from someones blog just for reference.(credit)
http://3.bp.blogspot...00/DSCF2855.JPG
#69
jj0000
Posted 05 October 2010 - 10:10 PM
jj0000
  • 16 posts
Today i go survey tyre shop and ask advice for rim. I asking why two of these same inch rim, but different prices so much. He said one is import rim, one is local rim. Different is material to produce these rim. Import rim got mix with alloy material, weight less than local rim. So if take import rim, car will improve FC cause car weight has reduce and more steady when driving on highway.. Is all of that true? sifu?
Some more, he suggest, if take 16" rim, take 195/50 with tyres. That's will improve FC as well, is that good?
#70
dabdab
Posted 05 October 2010 - 11:21 PM
dabdab
  • 470 posts
QUOTE (jj0000 @ Oct 5 2010, 10:10 PM) <{POST_SNAPBACK}>
im not good at rims.
these days putting 16 inch is expensive, tire is nearly the price of 17inch.
but 16 inch with 205/45 is the best fit and the corner is really sharp and 205 grips good for this car, im afraid putting 50 series might be a bit of issue because its a bit taller, frankly im not sure about clearance and if any scraping or rubbing might happened.
45 series rides a bit harsh. but sharp control
mine is 50series with 15inchers. it compensate some ride comfort from my stiffer spring. cornering not bad though.
to be on the safe side i use t from other brand car standard 15 inch rims at the same hole size (pcd 100) and shod wit 195/50. 50 series is sharp at corner but you will experience a sharper turn with 45
but if u go for after market light weight, light weight rims although made in taiwan or korea or local the wheel will be embossed with the word 'light weight' and the rim itself 1000rm plus.
if you have wider tire of course its heavier, to compensate,,use lighter wheel. and if you are talking FC then i would say +- only marginal effect due to the wheel.
but if you are using taller tire it might give a slight batter FC in a long distant highyway . but FC might suffer a bit in stop and go town drive since the gearing ratio is taller now due to diameter of the tire increased . and initial push for the car is heavier and also might effect acceleration. - theoretically.
