help with speaker wiring
Posted 09 February 2005 - 11:09 PM
need your help.
i just got a new cd player installed in my waja.
the problem is i think the guy did a bad job, the bass is simply non-
existent.
a fren mentioned that he faced a similar problem in his old car, and it
was caused by mis-wiring (+ and - wiring mixed up)
so im thinking of checking the wiring myself.
can you guys help provide what each colour of the wire in the car
represents?
cant find it in the manual.
cant find it anywhere in this forum too...
thanks
Posted 10 February 2005 - 08:01 AM
problem u are facing and ask them to check the wiring. I think should be
FOC instead that DIY it will take risk.
Posted 10 February 2005 - 10:43 AM
dismantle the front to fix the cd-player. would prefer to do it myself :)
the other thing is im now in my hometown for CNY, and will only be going
back after CNY. would like to get this fix so that i will have a more
enjoyable ride back :).
most if not all the shops here are closed. you know lar.... tangan gatal
wanna try it myself. :)
thanks
Posted 15 February 2005 - 02:09 PM
SONY XS-HF78 180W Speaker + Tweeter + Passive CrossOver
,(which i remove from my old car wan,,hehe!)
.basically is a component speaker set la..
after installation, my bass effect all mati kaput!!!,..i panic
lor,...so,..i jus try this out myself,...its the "-" and "+" cabling to
the crossover lor..
so,.i jus change 1 of the crossover setting,..joining the "-" cable to
the "+" terminal on the crossover and "+" cable to the "-" terminal on
the crossover,..and thats it!..all my bass effect comes back to live
liao!!...
cool!
Posted 15 February 2005 - 09:00 PM
May I know how many inch ur sony rear speaker? Please let me know if u do
mods on ur midrange speaker, what is the size? I have a plan to change it
to 6.5" any comment/is it able to fix it?
Posted 16 February 2005 - 04:00 AM
anyway, i advice u have non-OEM players run on island wiring, separated
from the original wiring.
Posted 16 February 2005 - 08:52 AM
my Sony Rear Component speaker is round wan and the size is the same size
as the Original Speaker ,..as i dont see the installer potong any part of
the metal bracket lor..
is original speaker 6 or 6.5 inch?...this wan im not sure lor..he just
slot it in,..screw it on,,.KAU TIM liao,..and do the wiring of course!...
by the way, i missed the part where he remove the rear seat 2 side
cushion lor,..if not remove, the speaker board cannot be slide out
ma...so,just wanna ask u know how to remove the rear 2 side(left and
right) cushion?..can give some tips on how to remove them arr?..
i think any speaker size bigger than the original speaker,,the existing
speaker metal bracket has to be potong /modified in order to install for
example a 6 by 9 or 7 inch speaker lor..
Posted 16 February 2005 - 08:58 AM
errr,..i just changed to Component speaker only lar,..no amplifier or
subwoofer installed also,,
and the most about the speaker wiring is,..if not install properly, no
sound come out only lar,..
wont short circuit wan,..its just like your those HiFi Set at home ma,,if
not wired properly, no sound come out only lor...
furthermore, im using all the original wiring, never modified those
wiring into good wan..
lets say if koyak also,,my crossover will koyak first before my speaker
set koyak ma..hehehe!
anyway, i change terminal changes liao,,and everything back to normal
liao!..cool!..
Posted 17 February 2005 - 10:05 AM
just found out that my SONY Speaker is 6.5" inch wan,...yeah,,and no need
to "potong" or do any modification to the existing speaker metal bracket
lor..
Posted 17 February 2005 - 10:37 AM
the BASS. Just swap back and it should be fine.
Waja Rear Speaker - 6.5"
Waja Door Speaker - 6"
