[official] Proton Exora Bold And Prime
hhc8
Posted 09 December 2014 - 02:51 PM
hhc8
  • 72 posts
My ABS is lighted again! Does anyone face this problem?
#612
Gunnerzz
Posted 09 December 2014 - 04:13 PM
Gunnerzz
  • 3,102 posts
QUOTE (hhc8 @ Dec 9 2014, 02:51 PM) <{POST_SNAPBACK}>
abs sensor.get it replace.
#613
hhc8
Posted 24 March 2015 - 10:45 AM
hhc8
  • 72 posts
My Battery died without warning after 37 months. Towed to and replaced at Proton Edar for RM384.70. Was told by Service Advisor not to jump start or jump start for other cars as the electronics are sensitive.
#614
mosh
Posted 24 March 2015 - 03:50 PM
mosh
  • 3,557 posts
QUOTE (hhc8 @ Mar 24 2015, 10:45 AM) <{POST_SNAPBACK}>
My persona much earlier. 2 years warranty. one month after the warranty date ended. the MF ramcar battery died.
then replace with aftermarket din55 battery around rm250.
wonder if CFE & the normal campro use the same battery ?
#615
weejin2000
Posted 22 April 2015 - 08:45 PM
weejin2000
My brother has an Exora Bold CFE, today the turbo is confirmed dead by 2 different mechanic. All this while, 3 yrs, he has his Exora serviced at Proton SC in Penang, and only after 3 yrs and 3 mths (warranty is 3 yrs), turbo is dead (something the shaft is broken/putus). Check engine light will come up and the error code will be P0299 Turbo...Underboost. To all Sifus out there, pls suggest the cheapest way to rectify this problem of my brother. Tq in advance
#616
dejavu1
Posted 13 August 2015 - 05:50 PM
dejavu1
  • 9 posts
Just to share..
11/8/15, My Exora Bold CFE (2012) started to jerk near Masjid Negara.  CVT gearbox and engine light up.  This is the 2nd time.  It was raining super heavy an hour before.
Called towing and went to Balakong SC.  Mechanic checked w diagnostic laptop, here are the diagnosis:-
1) Water from A/C condensation in the dashboard area was dripping into CVT Computer box.  The box located behind centre console panel of dashboard. CVT computer box new costs RM2800.  Mechanic said will try to repair but usually not succesfull and need to replace.  Newly facelift model rectified this problem.
2) Aircond compressor magnetic coil also damaged.  Cant replace just the coil, have to replace whole A/C compressor.  Costs about RM900. Can not use recond compressor bcos not available (really ah?)
3) Radiator leaking at underside area.  Mechanic said can be repaired, might not need to replace radiator.
Just to let u guys know about the CVT Computer box thing. get it checked...The first time (last year) CVT light on was because of faulty sensor.  Now they just can not reset the problem with computer.
#617
hhc8
Posted 29 February 2016 - 11:53 AM
hhc8
  • 72 posts
Went to change my front original GT Radial tyres at the shop after 42K because of uneven wear to Falken Made in Thailand RM220. Shocked to see that the side was also cracked when he removed it., Better check your tyres.
He also change my front brake pads to Absolute brand RM165  without any manutacturer name or address. Later advised by PE  to change back to original brake pads RM400 plus coz the other brand may damage the disc. Is he correct?
#618
Posted 29 February 2016 - 11:42 PM
  • 71,470 posts
Your original disc pads cost RM400?.....fuh!
Disc pads depends what grade you buy. Semi metallic pads bites better when hot and resist fade but they do wear the disc, unless you get entry level pads like Bendix General CT. These pads won't wear your disc but cannot withstand too high a temperature like repeated braking coming down from hill resort
