Problem with Vios auto transmission
babylexus
, Oct 29 2006 09:49 AM, 42 replies to this topic
Posted 01 November 2006 - 08:28 PM
SPS youre wrong. shift lock is for when no key in the ignition or brake
pedal press while u still can shift your gear from P to R with Shift Lock
button pressed. evryone can shift from P to R without shiftlock button
depressed, if youre driving a tyt u should know.
I am indeed driving a Toyota, and this is the 3rd one too. Ifyou can
shift from P to R with the car started, without depressing the shift lock
button, suggest you go check with UMW
Posted 02 November 2006 - 01:11 AM
I would be very surprised if you have been able to engage R
from P without depressing the shift lock button first.
what's so surpised about that?
Posted 02 November 2006 - 01:12 AM
babylexus.. tyt warranty is 3yrs/100k km ma... since yours is 2.5yrs n if
less than 100k kms then send it back to tyt lo.
Posted 02 November 2006 - 07:11 AM
Thanks everybody for the info, I'm glad that it's a minor problem.
Posted 02 November 2006 - 07:31 AM
The shift lock button is a safety feature. It is there to ensure that
when you attempt to shift into reverse from P, it is a conscious and
deliberate act(and therefore the button is depressed first) and not
accidental.
I sincerely recommend you verify from UMW service centre if you can push
the gear lever of your car from P to R without depressing the shift lock
button.
accidental.
button.
Posted 02 November 2006 - 08:32 AM
accidental.
button.
if d car's engine is not
running, u kenot shift
from P to R w/o pressing
d shift lock button
running, then u can shift
d shift lock button but
u hv to step on d brake
pedal
accidental.
button.
d shift lock button
pedal
Posted 02 November 2006 - 01:32 PM
push, when car not running, with ignition key turned on position (without
twisting into starter mode)...can shift or not?
cefiro also got this button, but never tried to shift before starting...
Posted 02 November 2006 - 01:43 PM
Original Poster : babylexus
Original Post : Thanks everybody for the info, I'm glad that it's a minor
problem.
thank god. otherwise my perception on toyota would have been worse liao..
been thinkin' about changing my 2005 Spectra to Vios.. wondering how much
the trade-in value would be for Spectra...
problem.
