thanks alpinev18,
already did that n make full use of my 180W Component Speaker liao!..
bass is back!..
now looking for an Amplifier,..4 Channel preferably,..any idea how much
would it cost?.including installation of course,!...i dont wanna spend
too much on the amplifier also lor...
budget is around RM200++ lor....
help with speaker wiring
shad0wmag3
, Feb 09 2005 11:09 PM, 16 replies to this topic
Posted 17 February 2005 - 12:43 PM
N4speed,
FYI, rear seat having internally 2 latch (left and right)on top of
cushion,u need to pull together. Same thing goes to bottom rear seat
having 2 latch on bottom near the to the carpet. 1 thing for the
left/right rear cushion fix by a screw mounting.After removed the rear
seat u can see this screw mounted to the body.
I'm fixed with oval speaker but need to add additional kit to holding the
speaker.I think ur speaker is fix like normal size speaker. I having a
vibration problem using this speaker if i'm enter at uneven road.
(trek..trek sound) giving me additional base.. I'm plan to change to
another speaker that why I'm asking the rear size speaker. Current
speaker I'm get it for my previous car, that one i'm using almost 5
years. Now try to looking for a new one. I'm upgrade my player to kenwood
KDC MPC-7023. May be u can have sharing what u fix on ur ICE.
Posted 17 February 2005 - 12:51 PM
N4Speed,
Don't know about your case. To me, I advise you to get a Good AMP. RM
200++.. not so good on the sound effect. A good Amp can last many years.
Save more $ and get an Alpine. Currently having Alpine V12, the vocal,
clearity on stock speaker is noticable.
Posted 17 February 2005 - 02:55 PM
fcbgaX,
i know how to remove the seat cushion,
remove the clip near the carpet ma..
and fold down the rear leaning cushion,...
with the 2 red button,clip on top of the cushion wan
but the 2 side piece(left + right)cushion must be removed in order to
slide out the speaker board ma...
u were saying there is a screw holding the 2 piece of cushion, may i know
the location of the screw holding that 2 piece of cushion?..
and yes, i believe ur using a 6 by 9 (egg / oval shape) speaker for your
rear,.as the original speaker is round wan,..not oval,,so, i think u have
to potong the metal bracket abit to accommodate such changes,as for mine
is round speaker 6.5" inch speaker will fit in ngam ngam wan,so no
modification/potong needed just slot in only.
well, my head unit is SONY CDX-F5500 (MP3/CDR/CDRW) Single Disc Unit,all
still running on original wiring,
front speaker still original 6" incher 20W wif ori "Tweeter" of course,...
rear speaker taken from my old car wan,..a pair of SONY XS-HF78 Component
Speaker Set (6.5" inch X 2),2 Dome Tweeter and 1 pair of passive
CrossOver (Adjustable)
and currently no Amplifier or Sub-Woofer yet lor...looking a good Amp of
course,,but very limited budget lar,,hehe!...
Posted 17 February 2005 - 05:58 PM
N4Speed,
The 2 side piece (left&right) cushion screw mounted located internally
but u need to remove the cover that cover up the body from center
position. I mean like a carpet behind your cushion.To remove this carpet
it have special clip.Just pull the clip. The clip look similar like your
door side cover.Once u remove the cover, u can see a screw for holding
this side cushion.
I'm still using standard wiring,right now no budget to upgrade to
amplifier or sub-woofer, plan to do it until budget cukup.
this side cushion.
Posted 18 February 2005 - 10:29 AM
me too, not enuf budget lar,..waiting for wallet to recharge
now,..planning to install Amp first,,then only bass tube,...as dont want
to sacrifice too much of my trunk space ma..hehe!..
by the way,
still having trouble locating the screw location,,hehe!...i have already
removed the seat cushion and fold down the leaning cushion,..now left
that 2 side piece cushion only lor...
by the way,
Posted 17 February 2015 - 09:08 AM
Hi there...
I need a help here....
Yesterday (16-2-2015) I purchased 1 set of 6.5 2 way speaker for my rear ...by the way I'm driving waja.
My current sound system is... A stereo Amp, 10" sub, 1 set rear, 1 set front and Tweeter
My Problem here is...my rear speaker no sound leh... I've checked the cabling everything... all same... but no sound... can anyone educate me here plz....
Thanks...
Thanks...
