Volvo S60 Or S80
jerrylauck
Posted 20 April 2014 - 04:35 AM
jerrylauck
Hi need some pro advice here. I am thinking to get a volvo car. 1st choice is comfort. I am not sure shall i consider S60 or S80 year 2011 model. I am concern how reliable the car. I dont have any friends driving volvo so i cant get any accurate information. What common problem of volvo car and what the major problem. Which model is more reliable? I hope you guy can reply me. Thank you very much
V406198
Posted 22 April 2014 - 10:38 AM
V406198
  • 2,151 posts
QUOTE (jerrylauck @ Apr 20 2014, 04:35 AM) <{POST_SNAPBACK}>
if you are not after power band but instead comfort then S80 2.5T are ideally for you, as this car are so comfort but some just said it's too comfort until it become boring... this car don't have much problem as I know as its the improved version of the first generation of S80.. BUT regular service for Volvo is essential as these car are designed mainly for cold country so our extreme hot weather here will eventually kill the parts sooner than what Volvo thought. so don't blindly follow what the Volvo recommended service scheduled.
since you intend to get used 2010 unit that have warranty expired.. better send the car that your like back to authorized service center ( federal auto ) to performance the inspection that will only cost your rm1xx and it came with full report of the car condition and recommendation. and if the car are bad then just give it out until you find the ideally unit.. my last advise is buying used Volvo need to be patient.
2004 S60R. AT. Tit Grey. Nordkap. 18" Pegs. TME SportCat Exhaust DP & Cat Back System. TME Lower Spring. Garrett GT3071R. RC 750cc Injectors. FMIC. K&N Filter. Pegasus 3" CAI. IPD HD TCV. IPD HD Ignition Coil, IPD 25mm Front Sway Bar. UR Custom 23mm Rear Sway Bar. UR Front & Rear Strut Bars. Stainless Steel Brake Hoses. Audi TT DV, Saab 900 ATF Cooler. TkiMotorSportRacing & IPD HD Link Rod. H&R 5mm Front Wheel Spacer. Endless Sport 0-400 Front Brake Pad. ScangaugeII Diagnostic Gauge. Stages 2 Snow Performance methanol Injection.
jamespaul
Posted 22 April 2014 - 11:22 AM
jamespaul
  • 180 posts
but if you are looking for comfort 1st. then Volvo's are champs. Amongst conti, they are the best.
if you have reliability as second, you may need to look elsewhere. the parts are really pricey as they dont have demand for them..
what is your budget? you can get a brand new S60 with 5 years warranty and service. it is very comfortable.
reliability isnt great as it shares it parts with Ford.
V406198
Posted 22 April 2014 - 05:28 PM
V406198
  • 2,151 posts
QUOTE (jamespaul @ Apr 22 2014, 11:22 AM) <{POST_SNAPBACK}>
wonder what parts are sharing between Volvo and Ford ? .......beside the engine.
jamespaul
Posted 22 April 2014 - 06:03 PM
jamespaul
  • 180 posts
QUOTE (V406198 @ Apr 22 2014, 05:28 PM) <{POST_SNAPBACK}>
gearbox
City stop tech
Blind spot tech
Chassis / platform
and others that i am not aware of.
V406198
Posted 23 April 2014 - 09:58 AM
V406198
  • 2,151 posts
QUOTE (jamespaul @ Apr 22 2014, 06:03 PM) <{POST_SNAPBACK}>
gearbox
City stop tech
Blind spot tech
Chassis / platform
smile_thumbup.gif smile_thumbup.gif infact ECU ME9 are similar as well as from same source
jamespaul
Posted 23 April 2014 - 12:54 PM
jamespaul
  • 180 posts
QUOTE (V406198 @ Apr 23 2014, 09:58 AM) <{POST_SNAPBACK}>
but the Ford uses a slightly older version vs. the Volvo one.
the Volvo City stop can stop up to 55km/h, where as the Ford on is only up to 35km/h (plus minus)
V406198
Posted 24 April 2014 - 10:48 AM
V406198
  • 2,151 posts
QUOTE (jamespaul @ Apr 23 2014, 12:54 PM) <{POST_SNAPBACK}>
O.. sorry i'm compare apple to apple interns of similar models of both Volvo and Ford, example like current S60 T5 Vs Ford Mondeo that both are on similar power output/performance..but is just the mapping for both are slight different.
