No Response On My Throttle
dreamist
Posted 12 March 2013 - 01:49 PM
dreamist
  • 86 posts
Hi dear forumers,
Today, I was as ussual drove my Persona to work. After I reached the highway, I suddenly felt that my car was slow down gradually. Then I stepped a bit deeper to the throttle, but useless, the throttle was no response. I drove my car to the most left lane and than stop it, then I stepped again the throttle. The RPM went up but very slow, I tried to accelerate my car with full step on my throttle but just able to speed up to 40km/h. So I decided to switch off my engine, after a few while of "engine cooling down" I restart my engine again then everything went back to normal...
What's going wrong with my car? Do you face the same problem as mine before? Thank you
mosh
Posted 12 March 2013 - 11:52 PM
mosh
  • 3,557 posts
QUOTE (dreamist @ Mar 12 2013, 01:49 PM) <{POST_SNAPBACK}>
Hi dear forumers,
i got the similar experience.. but it was caused by my aftermarket throttle controller ( e-throttle ) it went into save mode during spirited driving and sluggish. engine check light on. stop the car turn off. restart the car a few moment back, it went back to normal..
our pedal is drive by wire sensor. maybe the sensor got problem. have you do the resetting of the pedal ( they call it pedal respond ) before ?
dreamist
Posted 13 March 2013 - 09:04 AM
dreamist
  • 86 posts
QUOTE (mosh @ Mar 12 2013, 11:52 PM) <{POST_SNAPBACK}>
It's almost the same problem like yours, but mine Engine Check light did not turn on, only the moment I restart the engine (as normal lah). I didn't do any reset on my pedal respond... and mine throttle is original Proton one... mine is Proton Persona Elegance "Kosong Edition".
I'm suspecting my ECU... cause I saw a lot of Persona engine stop suddenly because of ECU problem in some forums, and it comes back to normal when they remap it.
jasondotcom
Posted 13 March 2013 - 02:31 PM
jasondotcom
  • 1,185 posts
how do you reset the pedal? btw i think u have a lot of performance tips for Persona AT.... Mind to share?
mosh
Posted 17 March 2013 - 01:11 AM
mosh
  • 3,557 posts
QUOTE (dreamist @ Mar 13 2013, 09:04 AM) <{POST_SNAPBACK}>
this one i say i agreed. a few of my friend got engine stop problem due and one of it, the car stop in the middle of driving. luckly it was on a slower speed and he was at the left lane. solve by remap ecu by proton.
mosh
Posted 17 March 2013 - 01:20 AM
mosh
  • 3,557 posts
QUOTE (jasondotcom @ Mar 13 2013, 02:31 PM) <{POST_SNAPBACK}>
you can try to reset throttle body your self. my friend have a guide buts it is in BM
http://eilarazi.blog...ottle-body.html
for the pedal respond. my mech adjust the pedal setting so it will have more responds ( speed up the signal from pedal to ecu ) when you step on the gas pedal. its kindda like you press 10%, its told the ecu that you throttle to 20% instead of the normal setting that you press 10%, you get 10% respond.
Gunnerzz
Posted 31 March 2013 - 08:12 PM
Gunnerzz
  • 3,102 posts
And i tot only waja 1.8 are prone to this prob.
Ont 1.8 its called cts sensor.other symtom are hard to start and jerky engine plus hessitation when accellerating.
dreamist
Posted 07 April 2013 - 04:47 PM
dreamist
  • 86 posts
Problem comes again!
The throttle pedal just respond "half"... As I full press the throttle pedal, the RPM only raise until 2500 (no gear). When I change it to 1st gear and move the car, it jerk~~~
mosh
Posted 08 April 2013 - 05:04 PM
mosh
  • 3,557 posts
QUOTE (dreamist @ Apr 7 2013, 04:47 PM) <{POST_SNAPBACK}>
time to go for a PADT checkup bro..
dreamist
Posted 09 April 2013 - 01:36 PM
dreamist
  • 86 posts
QUOTE (mosh @ Apr 8 2013, 05:04 PM) <{POST_SNAPBACK}>
Sorry of my "flog under the coconut shell", what is PADT stand for?
I just sent my car to the nearest service centre for checking just now, the technician said he had serviced the throttle body and re-tune the engine... I have to observe it for a few days and see whether the problem has been completely solved or not...
