Saga Flx(a) Engine Can't Start
Posted 07 October 2012 - 08:42 PM
but i experience 2 times engine can't start . 1st time early morning after heavy rain (during raya puasa), 2nd time its happen today (around 2pm). i start the engine , engine is running but got sound like "semput-semput". got yellow sign at odometer panel( at speed panel,). so i switch off the engine and retry again, engine running but still got sound 'semput-semput" & engine die off after a few second. i try a few time (more than 5 times) and after that engine run smoothly and yellow sign missing.
so u all got any idea what the problem?
thanks a lot.
Posted 07 October 2012 - 11:59 PM
thanks a lot
Plug coil.
Service center can detect it as engine light lit up.
Quickly go to a service center.
Posted 08 January 2013 - 12:38 PM
thanks a lot.
no need check already, it is knock sensor......plug in computer ,u can see the error. To repair under proton....whole engine need to take out from chasis and open up the engine to change it.... my SC already finish done a PREVE. My flx also 3 times already.
Posted 28 October 2013 - 10:34 AM
Posted 15 December 2013 - 01:49 PM
Every time this happens, I open the front hood, kibas-kibas sikit and then the engine can start. I don't think it's caused by high engine temperature as it happens even when the engine is cold.
Has anyone found out the actual reason for this problem? What should I tell my mechanic to check for? Each time I go to service my car at proton SC, they told me to use the petrol treatment to prevent this problem but even after using it the problem still occurs.
Posted 15 December 2013 - 02:28 PM
Posted 02 March 2014 - 11:11 PM
Posted 19 July 2014 - 10:07 PM
After letting it cool down about 15 minutes it can start, frightening.
As usual, the service center just say they will check whether it is solved or not I don't know.
Posted 29 November 2015 - 02:48 PM
i also have the same problem. cannot start the engine. i did force it to run many times with multiple try of ignition by battery jumping. but now i am tired. Please watch the video. Have any idea what is happening here?
http://youtu.be/E-ip-pm2ITw
Hello...i have the same situation like yours...Saga Sv..did your problem solved yet? if yes can u share what the is the problem..i been tried to start my car for 2 days. it give me a strees day
