Should I Change My Waja To B14?
Posted 04 September 2012 - 11:24 PM
the reason i thinking to change car is for cheaper FC & maintenance, also plan to use it until my retirement age which is abt 18 yrs from now, a bit worry waja can't last that long, so hope nissan can make it as many had said jap car have much longer life span.
thanks a lot.
Posted 04 September 2012 - 11:51 PM
thanks a lot.
waja FC and maintenance high ?
Posted 05 September 2012 - 09:19 AM
waja is abt 9.5km/L for my city drive, i suppose b14 should get higher than that, right?
also hv been hearing parts in nissan can last longer & more reliable than Malaysia car, although can be bit higher in the cost, but at least save me time from visiting my mechanic friend so often.
that's why i need advice from b14 sifu if the above "fact" true or not? thanks..........
Posted 05 September 2012 - 10:09 PM
9.5 normal lah...
your waja parts many rosak ?
Posted 06 September 2012 - 09:28 AM
i thought b14 can do better than 9.5?
my 9 year old waja didn't give much problem at the engine side, just recently some parts gave way already as their life span is up, past 12 months have changed fuel pump, mounting (4 pc), radiator tank cover, clutch & it's pumps, next may need to replace it's condenser as suspecting air cond gas leaking at that area...., same thing can happen to japanese car too, right? but i guess theirs can last longer.
actually the real concern is how long can the waja last, compare to b14, if both under proper care, can sifu share some insight?
Posted 07 September 2012 - 12:20 AM
mounting last 9 years not enuf ? sentra one 4-5 years start vibrate liau...
can do better than 9.5 depends lah.. then waja can do better than 9.5 ?
Posted 26 September 2012 - 08:48 AM
I suggest look for a new car is better.
Posted 11 May 2016 - 02:03 PM
Dun buy old car. Running out of spare parts especially old model like B14. I looked for ages for a replacement Brake booster. The Tan Chong Workshop in Ipoh wished me "Good Luck".
