#41
byebye2u
Posted 14 November 2011 - 08:34 PM
Hi bro, your's have ESP ??? mine dont have this prob , even how i spin my tyre check light also dint come out, what error the scanner give ?
mine also 2004.
oh oh..you mean you can spin until smoke the tyre no check light.
last time dyno also very hard and yes the ESP light come out too..mmmmm...funny..
will let you know what the error code when I scan.
#42
neonlee
Posted 14 November 2011 - 09:00 PM
Dr Hillious also tested mine till type spin.. no check engine light come out..
#43
r3xt0n
Posted 19 February 2012 - 11:09 PM
My rexton is rx270xdi has a problem with power.when ever i accelerate it doesn’t run as fast normaly.turbo and his sensor has been changed and all of engine system EGR,manifold,fuel filter,intercooler turbo,radiator all the piping all has been cleaned and yet still not power.then indicator light still appear.the car still no power.what could be the problem.could be the glow plug ?
If there is problem with glow plug, you will have difficulty starting especially during morning but it won't be in use after that, unlike petrol engine. Lack of pickup power is most likely due to Vacuum Modulator or vacuum hose leaking/blocked if your turbo is working fine.
#44
byebye2u
Posted 20 February 2012 - 12:27 AM
You mean now new turbo?what about the actuator?on bro azhar after search high/low we found that the actuator screw tercabut, turbo not open, low pressure will cause the check light too.
If still cannOt could be the vacuum modulator.
Best find a workshop with scan 100, where do you live, maybe we can recommend a few mechanic.
Nik
#45
nas75rex
Posted 21 April 2012 - 11:58 AM
nas75rex
mine got problem with water separator always light on while drive, already change water and fuel filter but the light still goes on.
happen almost. dont know what going on?, it related to wiring or sensor?
any idea?
rexton 1616
#46
byebye2u
Posted 21 April 2012 - 12:23 PM
any idea?
what about your vacuum modulator?
mmmm last night bro joe gear cannot engage, so i ask him to cabut the battery for 2,3 minute. he did and call me every thing back to normal!!!
why don't you try cabut the battery too, who knows can make the hantu hilang...
#47
r3xt0n
Posted 21 April 2012 - 07:10 PM
any idea?
Did you changed the sensor attached with the Water Separator when you changed? Normally you will need to change that sensor (about RM80) together with the Water Separator. After that, need to reset to remove the error code.
#48
nas75rex
Posted 27 April 2012 - 04:45 PM
nas75rex
ya i think so, never change the sensor. anybody here sold the sensor..or recommend shop or can suggest?
rexton 1616
#49
chrisss
Posted 29 April 2012 - 02:28 PM
My senor is also due for change, the warning light keeps coming on with the annoying six beeps....
I had it checked several times in Teng's workshop, no water inside, only error code in scan. I will have it changed with other service to be done.
You can try and use WD40 on the contact of the sensor, that might fix it already.
If you want to change the sensor, be aware though, according to Teng there is a new generation of this sensor which replaced the "old" design after giving lot of problems.
Cheers,
/C.
Join Rexton Hub on FacebookRexton 270 Xdi, black over black leather, 2005
Mods: Eco 2.0 Remap with EGR delete, UR racing bars, RSpro steel brake hoses, Ixion front grille and eyelids, Eco-Tint, HID main & foggies, Hyunkia absorbers, LEDs cabin light, Meguiar detailling job.
Pipeline: Arnott air suspension front & rear, body job front bumper & grille, body kit job rear bumper & double exhaust after removing spare.....To be continued.
#50
allan69
Posted 29 April 2012 - 06:45 PM
allan69
Cheers,
/C.
Below is a previous advice from Bro r3xt0n to me.
"NEVER clean any connectors with WD40 (it is oil lubricant base), you should use Contact Cleaner. Can get from spare part shop or electrical shops
[attachment=5142:Contact_Cleaner.jpg]
My Rex is currently with Ecomap, customized Turbo Vacuum Hose, K&N Drop in Filter, Bendix 4WD Brake Pad (Front & Rear), Petronas Urania SUPREMO CI-4 Lubricant Oil, FUCH TiTAN ATF 3353, Rear Coil Dampener, Tufoil Engine Treatment, HID 4300K, . . . . .
