Berlingo Ii
tny
Posted 24 March 2012 - 11:23 AM
tny
  • 11 posts
Nice. Now you can do your keys. Wheels ever so slight only. It's fixed, there are no links etc to adjust back there.
#32
ensaaj1969
Posted 27 March 2012 - 12:49 PM
ensaaj1969
  • 169 posts
QUOTE (tckuan @ Mar 23 2012, 09:00 AM) <{POST_SNAPBACK}>
i noticed from the rear the rear wheels seems like bit slanted/senget with top part more inwards, should i do alignment/balancing?
You can go to any shop that have wintoe. The software provide wheel specification for most car model. The shop owner may also request for belingo if the wintoe do not have it
Abdul aziz jaafar
My Best Old Man Toy : Citroen C4 2005
#33
tckuan
Posted 31 March 2012 - 09:03 AM
tckuan
  • 109 posts
hi, i notice that if i drive >80kmh, the rear part of the car tends to 'vibrate'/humming sound. is it wheel bearing issue? shd i do alignment etc first b4 changing bearing (if got wear)? found that 'rod cover' is torn, mech say need to replace whole rod/line sub cos it is a 'complete' unit. is it correct? tq
#34
tckuan
Posted 13 April 2012 - 09:10 AM
tckuan
  • 109 posts
managed to find out the reason for car shaking at speed, rear tyres bulging. changed 2 new ones and smooth ride again. i notice loud squeaking sound from engine area everytime during start up, wonder what is it?/ still waiting for window lifter, side mirror and steering rack parts to arrived, fr spain, i think!
#35
spmoi
Posted 16 April 2012 - 04:26 PM
spmoi
  • 220 posts
QUOTE (tckuan @ Apr 13 2012, 09:10 AM) <{POST_SNAPBACK}>
squeaking sound might be caused by air-con or alternator belt. try to check on your air-con or alternator belt.
camus
#36
tckuan
Posted 19 April 2012 - 09:18 AM
tckuan
  • 109 posts
QUOTE (spmoi @ Apr 16 2012, 04:26 PM) <{POST_SNAPBACK}>
was told by mech it's the steering issue, cos the sound happens when start up car and turning steering, will hv to wait till replace new steering and see how it goes. thanks for reply.
#37
tckuan
Posted 10 June 2012 - 12:34 AM
tckuan
  • 109 posts
spent more than 5k replacing all the needed wear/tear parts, car is running smooth. only 1 issue left to sort out, the steering column (used) is more heavier feel compare to the 'original', mech flush steering fluid twice still the same. pump is ok, any idea what is wrong?
#38
tckuan
Posted 27 August 2012 - 11:50 PM
tckuan
  • 109 posts
it's hard to make a duplicate key for my berlingo in penang. all key shops asked me to get from dealer. any other way? tony can make it but i m fr penang can't send my car there. thanks.
