Sudden Loss Of Power Steering!
Posted 06 February 2012 - 11:32 AM
It really gave me a fright.
I pulled on the brake release lever and the ligfhts went off and steering became normal.
This happened again a few km later.
Can anyone hazard a guess as to what theproblem might be?
In any case, pls recommended a good workshop in the Cheras/Kuala Lumpur area as the Cheras Naza Kia workshop has moved or closed down.
Thanks a bunch!
Stay young and active with BiHRT.
Facial Rejuvenation with PRP.
Posted 07 February 2012 - 05:49 PM
http://forum.autowor...showtopic=96682
Thanks a bunch!
Posted 20 February 2012 - 06:19 PM
telah berlaku 2 kali situation ini . both happened during wading air (hujan) lebih kurang 3-4 inci. buat masa ini saya suspect Traction Control / Electronic Stability Control pre-matured activating.
Klimal,..if you found what the cause...please share this. expert2..please advice
Thanks a bunch!
Posted 22 February 2012 - 01:28 PM
Rondo does not have Traction Control or ESP, only ABS.
I sent the car to the Chan Sow Lin SC twice and both times, they coundn't detect any fault.
They reset the ECU and on the second visit, I raised a stink.
They then said they will make an appointment with the Technical Team to look into my issue.
Today is the 2nd day since, am still waiting for their call.
I spoke to the foreman and he was also lost. Initially said the belt was slipping from water contact but this also happened on a dry day.
Then he made a call and after that, he said it could be the ABS pump.
Now the car sits at home, my wife dare not drive it as it happened 4 times during the last drive, while it was raining.
Posted 27 February 2012 - 12:19 PM
if the belt was slipping, solutionnya tentu mudah. just tighten it back. only if the cause is another worst thing...saya tak ada pilihan kecuali terpaksa memandu juga sebab tak ada 2nd car. only to be more carefull when rainy.
about the ESP, that what i ve believed it to be included in malaysian market since foreign model all include it. see australian rondo http://www.zercustom...ia-Rondo-7.html
Posted 27 February 2012 - 05:11 PM
Posted 25 April 2013 - 06:02 PM
Whoever has the solution for this Sudden Loss of Power Stering problem, please share here.
My Rondo already encountered this incident quite a number of times 100% during heavy rain. The problem is I personally never encounter this kind of problem only happened when my wife drove it back from work so I cant tell exactly what actually happened but from wife explaination seems tally with you guys problem in this thread.
Thank you.
Posted 20 June 2013 - 01:08 PM
1) IA RONDO YEAR 07 POWER STEERING FREEZES IN WET WEATHER DUE TO MOISTURE SPRAYING ON THE POWER STEERING BELT CAUSING SLIPPAGE. MANUFACTURER HAS IDENTIFIED THE PROBLEM VERBALLY, BUT REFUSES TO CORRECT OR DOCUMENT THE PROBLEM IN WRITING.
2) Maybe try replacing the drive belt everyone. I changed mine out and noticed that despite the belt looking fine on the outside, the underside was sticky with grease and gum. So was the entire side of my engine block. I think someone spilled a lot of oil and managed to get some on the belt causing it to degrade rapidly. Once I changed the belt, a funny little noise I used to hear when the A/C was on is now gone. Another funny little noise I used to hear when I would give throttle from a dead stop is gone. I've driven through some puddles lately and so far so good. That used to be a problem. Even the slightest bit of water would cause me to loose steering, A/C and alternator.
___________
put bigger cover below the engine to avoid moisture goes to the belt.
Posted 20 June 2013 - 03:53 PM
Jun 14, 2012 - Monroe, NC - Steering
ON 5-9-2012, IT WAS RAINING HEAVILY. MY RONDO, WHICH DROVE FINE THE DAY BEFORE AND THE DAY AFTER, STARTED MAKING A LOUD SCREECHING NOISE AND THE STEERING BECAME VERY "TIGHT" FEELING. I PULLED OFF ROAD INTO A PARKING LOT, AND WHEN I DID EXPERIENCED TOTAL LOSS OF STEERING CONTROL. I CAME VERY CLOSE TO CRASHING INTO THE PARKED CAR BESIDE ME AS A RESULT. I WAITED A FEW MINUTES, RESTARTED THE CAR. PULLING OUT OF THE PARKING SPACE, MY VEHICLE BRAKES ENGAGED SUDDENLY WITHOUT NOTICE, AND MY SON AND I WERE GRABBED BY OUR SEAT BELTS AS OUR BODIES WERE THROWN FORWARD SO HARD. I WAS BLOCKING TRAFFIC SO I RESTARTED THE CAR, AND IT DROVE OK ON A STRAIGHT ROAD, BUT WHEN I TURNED, AGAIN LOST STEERING. WHEN I SAY LOSS OF POWER STEERING, I MEAN WITH ALL MY MIGHT I COULDN'T GET THE CAR TO GO WHERE I WANTED. THE RAIN STOPPED AND I HAD NO FURTHER PROBLEMS UNTIL YESTERDAY, 6-13-12, WHEN IT HAD BEEN RAINING AGAIN. THIS TIME, PULLING ONTO A BUSY ROAD, MOVING QUICKLY DUE TO THE APPROACHING TRAFFIC, AND AGAIN LOST ALL ABILITY TO STEER. FORTUNATELY I WAS ABLE TO SLAM ON MY BRAKES AND GO IN REVERSE TO GET OUT OF THE PATH OF ONCOMING TRAFFIC, BUT HAD THE CIRCUMSTANCES BEEN DIFFERENT, MY YOUNG CHILDREN AND I COULD HAVE SUFFERED A CATASTROPHE. NHTSA HAD TWO SIMILAR REPORTS WITH THE 2007 RONDO: INTERNAL SEQUENCE NUMBER #736XXX DATED 8-23-09 AND #749XXX DATED 12/2/2009. I HOPE NHTSA AND/OR KIA ADDRESSES THIS PROBLEM BEFORE SOMEONE IS INJURED OR KILLED. "PARTS OF THIS DOCUMENT HAVE BEEN REDACTED TO PROTECT PERSONALLY IDENTIFIABLE INFORMATION PURSUANT TO THE FREEDOM OF INFORMATION (FOIA), 5 U.S.C.552 ((6).
Posted 11 September 2014 - 11:41 AM
