#21
wlution
Posted 24 October 2011 - 11:58 AM
wlution
hi,
i m not a rexton owner, instead i drive a pajero sport.
i m interest in titan HPE ultra but the problem i from JB.
do any bro here know any contact for titan in JB?
thanks...
Order & Payment Deadline - CLOSED
Order Collection - 22 Oct 2011
1. Engine Oil Package
i. Engine Oil Titan HPE Ultra 15W40 - 18 litre pack (sufficient for 2 change interval) - $240
ii. Bosh Oil Filter - 2X (sufficient for 2 change interval) - $20/piece X 2 = $40.
Recommended change interval - 5,000km ~ 7,500km depending on drive condition.
2. ATF Oil Package
i. ATF Oil FUCHS Titan 3353 (as specified in spec)
- 5 litre/container (sufficient for 1 drain-off) - $250
- 2 X 5 litre/bottle (If full flushing, require 9.5 litre) - $500
ii. Mayle Germany ATF Filter with Gasket - 1pcs - $100
Recommended change interval - 40,000~60,000 km depending on drive condition.
3. OEM Hyunkai Absorbers (Front & Rear) - RM100 each X 4 = RM400
4. Bendix 4WD Brake Pad (Front & Rear) - RM290
5. Rear Shock Stopper - RM75/each = RM150
6. Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
7. Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
8. Transmission Mounting - $130
9. 1 set Engine Mounting (2pcs) - $130 X 2 = $260
10. Vacuum Modulator - RM250 each X 2 = RM500
11. OEM Vemo Coupling Fan Clutch = RM250
12. Coolant Sensor - $75
13. Air Filter (OEM - Made in Korea) - RM60
14. Diesel Filter (OEM - Made in Korea) - RM180
15. Water Seperator (OEM - Made in Korea) - RM250
16. Bendix 4WD Brake Pad (Front & Rear) - RM290
17. Contitech Fan Belt (2257) from Germany - RM80
18. Aircon Cabin Filter (Korea OEM) - RM50
19. Crank POS Sensor Sensor - RM150
20. Cam Sensor - RM170
21. Tie Rod & Rod End - RM190 / set X 2 side = RM380
22. Tailgate Gas Struts Lifter (Window) - Local brand = RM90 / piece
23. Gas Struts Lifter (front bonnet) - Genuine Original = RM 130
24. Power Window Motor = RM190
25. Rear Brake Shoe - Original = RM 450 / set of left and right
26. Glow Plug - Original - RM90 per piece
27. Thermostat & Gasket - RM130 / set
28. Front Brake Disc (Left & Right) Original - RM650/set
29. Rear Brake Disc (Left & Right) Original - RM600/set
Order List
1. Tkw138 - RM320 - Paid
2. Urchirex - RM50 Paid
3. JailOs - RM500
1. Bosh Oil Filter - 1 piece - Paid
4. Neonlee = $525
- Tufoil X 3 = $165
-Upper Arm Bush (2pcs left & 2pcs right) - $30/pc X 4pcs = $120
-Lower Arm Bush (4pcs left & 4pcs right) - $30/pc X 8pcs = $240
5. Zak - $410 - PAID
2 pcs Gas Struts Lifter (front bonnet) - Genuine Original = RM 130 X 2 = $260
Rear Shock Stopper - RM75/each X 2 = RM150
6. tsleong67 - $650 - PAID
- ATF Oil FUCHS Titan 3353 (as specified in spec)
- Mayle Germany ATF Filter with Gasket - 1pcs - $100
- Aircon Cabin Filter (Korea OEM) - RM50
- Water Seperator (OEM - Made in Korea) - RM250
7. GreyDevil - RM410 - Paid
i. Voltage Stablizer - RM160
ii. Grounding Cable - RM120
iii. Transmission Mounting - RM130
8. wsxnasser - $350 - PAID
2. ATF Oil Package
9. BK4t9 - RM360 - PAID
14. Diesel Filter (OEM - Made in Korea) - 2 X RM180 = RM360
Total Order = RM3,844
Payment Paid = RM2,550
Bros who wish to make their order, please post your list here and payment instruction will be PM to you.
r3xt0n
Posted 24 October 2011 - 03:02 PM
hi,
thanks...
What is the engine oil spec specified by your user manual? Different engine required different grade of Engine Oil.
The best way is to join one of our gathering and collect it on the spot.
r3xt0n
Posted 27 October 2011 - 03:18 PM
I will PM on the collection arrangement to bros who have not collected their order items and items that is not available yet. The Committee Member incharge are away and occupied this week.
marthandan
Posted 31 October 2011 - 06:46 PM
marthandan
bro just got my rexton last week.. too late to order ? on the 4th Nov will be at KL.. 5 th.. can go servicing.. Still got parts available? I am looking for left side mirror.. too.
r3xt0n
Posted 01 November 2011 - 10:24 AM
What parts do you need? Our next gathering will be on 19 Nov in Penang.
Left side mirror, got to source for it. Have not bought this item before. Why do you need to replace it?
marthandan
Posted 01 November 2011 - 11:44 PM
marthandan
I cant make it to Penang bro. Need items for oil change, atf change, absorbers and bushes. Bout the side mirror.. my car dealer will settle it. It was bought broken..
r3xt0n
Posted 04 November 2011 - 08:35 PM
Both Bro RX270XDI and Bro Razopower is busy with their works, so probably could not make it to arrange for Group Buy for a period of time. Check back this thread again when I post new updates.
Posted 09 November 2011 - 06:51 PM
zak
Hi R3xton,
Any news on how to collect my items?
Don't mind if I top it up for courrier charges, that is if you have the time to do it.
Interested in the Engine oil package, but how to collect it? Cannot make it to the Penang tt
Any ideas?
Thanks
r3xt0n
Posted 10 November 2011 - 08:44 AM
Hi R3xton,
Any ideas?
Thanks
Your item has been waiting for your collection since last gathering. Where are you located?
Engine oil is 18 litre pail, so going to be more costly to courier. If you around KL/PJ, easier to collect them directly.
Posted 12 November 2011 - 09:30 PM
zak
Hi R3xt0n,
I am from Temerloh, Pahang.
Can you give me the address so that i can collect them along with the Nov.Engine oil package.
Better still give me the gps location.I do get lost in kl, Haha
Thanks Again
