byebye2u
Posted 15 February 2011 - 10:37 AM
nice info bro teerex
thanks for sharing
r3xt0n
Posted 15 February 2011 - 11:24 AM
Hi Bros,
Found this from the net.
The units operation consists of two main parts
• The viscous coupling.
In the housing there is a wheel with fine grooves which runs in the also finely grooved housing to which the fan blades are attached. Between the housing and the wheel is silicone oil. Now a property of this oil is that it's viscosity is not so much depending on temperature (as with normal oil) but on velocity. The greater the oil velocity the greater the viscosity. The greater the difference in speed between the oil layer on the housing and the oil layer at the wheel the thicker the oil becomes and so the wheel (which is attached to the water pump shaft) takes the housing with it and the fan turns. As the fan speeds up the speed difference decreases and the silicone oil gets thinner....thus less driving force.....this system prevents the fan from over revving and limits it turning speed at about 2500 rpm
Another oil to check and change? Mine is a little tight, can check and compare during PG TT, remember ok?
teerex
Posted 15 February 2011 - 04:38 PM
Hi Bro,
I have removed my viscous clutch fan 2day, tried looking for that 'forbidden' hole to re fill the silicon oil. Sorry la! bro, cannot find the hole la! old olredi cannot see well.ha ha ha! Oil got sell rm 15/= but rexton got no hole ha ha ha !
The ultimate measure of man is not what he stands for in moments of comfort or convenience, but where he stands at times of challenges and controversy.
r3xt0n
Posted 15 February 2011 - 04:47 PM
Hi Bro,
Buy the oil for me too. I will get my mechanic to see if they can find the hole better. Must have some way to enter the oil or Rexton don't use oil to lubricate, self nature wet... hhehehehe
teerex
Posted 15 February 2011 - 06:40 PM
Hi Bro,
oil can buy, test first whether yours need to fill or not first.If it is full wat is the point.??? waste Rm.
r3xt0n
Posted 15 February 2011 - 10:13 PM
Hi Bro,
Tested my Fan is a bit tight, not sure if the oil needed to change or not. So, better stand by the oil to change if necessary.
teerex
Posted 15 February 2011 - 10:16 PM
Hi Bro,
I will get the oil for you la! Any more orders????
r3xt0n
Posted 15 February 2011 - 10:22 PM
Hi Bro,
I want the door visor too but can't wait for the Group Buy to order together. Other stuffs will got to go KL to buy and fix after CNY.
byebye2u
Posted 15 February 2011 - 11:06 PM
just came back from Prawn Village Tambun..yummy yummy..hahahaha..and notice the alternator pulley giving constant noise , try spray reduce a bit...mmmm next friday might come down early to KL to buy it..they have available stock or need to call to order???
teerex
Posted 15 February 2011 - 11:11 PM
Hi Bro,
Better call and order first b4 you come. If possible change the armature bearings together. Dun become like me, opening it so many times.
