Ssangyong Rexton Hub
byebye2u
Posted 19 September 2010 - 01:30 AM
byebye2u
  • 2,805 posts
QUOTE (rx270xdi @ Sep 19 2010, 01:20 AM) <{POST_SNAPBACK}>
Hi Bro,
Bro how much they cost for replace the bearing..? because i just bought the NTN 32008X for front wheel bearing, as i know SC charge for rm4xx plus for one side, outside machenic cost rm210 one side.
Hi rx270xdi,
2 bearing cost me RM84, i buy it myself ( i'll PM you the company address )..plus change the engine oil, change coolant,change power steering oil, check the brake pad, replace the bulb, check the gear oil..everything the labour only RM60-00
NIK
#472
byebye2u
Posted 19 September 2010 - 01:39 AM
byebye2u
  • 2,805 posts
QUOTE (r3xt0n @ Sep 19 2010, 12:49 AM) <{POST_SNAPBACK}>
This is the same case today.. a white Alphard keep tailing me at 120kmh and the left lane is full, so no chance to give way to him. My Rexton is full load with 5 adults + 3 kids + luggages, plus in law on board, so must behave on road. When reaching Sgi Perak stretch with slight climb, just release fuel pedal awhile and then fully floor it with a thick black smoke bombing the Alphard and accelerate to 140kmh climbing leaving him behind in thick black smoke. He can't even accelerate to catch up with me... hehehe..
Now the black smoke is good defensive weapon against those who like to tail your backside, you can really smoke him and the black smoke is really thick blocking his good view.
ha ha ha ha, especially those just come out from car wash sure don't want to follow behind sterb292.gif
#473
rx270xdi
Posted 19 September 2010 - 01:44 AM
rx270xdi
  • 765 posts
Hehehe.. wait if his injectors really clogged up, it must be your curse then
[/quote]
Hahahah!! bro ,
Actually! he suspected by him self for injector clog up, and also the fuel filter, because the engine check light appearance! as for today! when full throttle at the NKVE highway, engine check light appeared again, higher the speed which will require higher the fuel supply or flow rate.
#474
byebye2u
Posted 19 September 2010 - 01:51 AM
byebye2u
  • 2,805 posts
QUOTE (rx270xdi @ Sep 19 2010, 01:44 AM) <{POST_SNAPBACK}>
Hahahah!! bro ,
yes..must be the diesel filter, the same thing happened to me before I replace it, then engine check light + limp mode = sure more milage..hihihihihi
btw..don't worry, the injector don't clog up first, the jerking is cause by safety mode to prevent further damage but don't wait too long.
#475
rx270xdi
Posted 19 September 2010 - 02:09 AM
rx270xdi
  • 765 posts
QUOTE (byebye2u @ Sep 19 2010, 01:30 AM) <{POST_SNAPBACK}>
Hi rx270xdi,
NIK
Thanks Bro,
As i know the original wheel bearing is KSB from Korea, same factory as FAG, and how you find the bearing numbers..? 32009..? by actual bearing take out from your wheel..? because i only manage to find 32008, i tot both bearing is the same size.
That company is my regular supplier at PJ, but they don't have FAG, or the NTN. i bought the NTN 32008X from others supplier, coat me rm2x over to rm30 for the NTN 32008X. If rm84 you can get from Hankok at Rawang, with the oil seal as well.
#476
r3xt0n
Posted 19 September 2010 - 02:14 AM
r3xt0n
  • 5,148 posts
QUOTE (byebye2u @ Sep 19 2010, 01:18 AM) <{POST_SNAPBACK}>
the humming come from below the car and I can feel a slight vibration when the speed reach 70km/h. have you tested with the window down?
Petronas Urania CJ-4 feel the same like previous oil, maybe after 5000 km or...I'll check the milage to see if any improvement later this week.
but changing the power steering oil does give some improvement, much smoother and lighter than before.
hey...1400km...you really raya than me..hihihi
NIK
Under 100kmh, very quiet. Have not thought of testing with window down, will try tomorow. My engine oil coming 5,000 km soon, can feel engine heavier when after running long distance. Maybe the service center did not use CI-4 during previous change. Will try out CJ-4 during next change.
I Raya 10 days mah, more like tour van driver la hehehe...
#477
byebye2u
Posted 19 September 2010 - 02:22 AM
byebye2u
  • 2,805 posts
QUOTE (rx270xdi @ Sep 19 2010, 02:09 AM) <{POST_SNAPBACK}>
Thanks Bro,
Hi rx270xdi,
the one I get is TIMKEN bearing no 32009 XJA, the original on my rex is from Korea - KBC bearing no 32009 XJd .
there are 2 bearing for each side and 32009 is bigger than 32008.
the smaller one on mine is also from korea - KBC bearing no 32008 XJd, replace by NSK - 32008 XJA.
milage now 140500km, not sure how long the replacement will last.
Got the no from the company I pm you.
cheers
#478
r3xt0n
Posted 19 September 2010 - 02:24 AM
r3xt0n
  • 5,148 posts
QUOTE (byebye2u @ Sep 19 2010, 01:23 AM) <{POST_SNAPBACK}>
2300cc is about RM680-00.
http://www.cars-data...6123/specs.html
average about 12.3l per 100km or RM22.75...RM0.227/km
From the spec, I noticed it do not has the following as compared to 270XDI which is quite important for a SUV. If the price difference is not significant, I would opt for one that comes with them. With 4 speed, I bet it is not going to be fuel saving.
Transmission: 4 speed, automatic
Electronic Stability Program (ESP): No
Traction control: No
#479
r3xt0n
Posted 19 September 2010 - 02:27 AM
r3xt0n
  • 5,148 posts
QUOTE (byebye2u @ Sep 19 2010, 01:39 AM) <{POST_SNAPBACK}>
Hahaha.. the black smoke bomb is under controlled, at least under normal acceleration there is no black smoke on mine yet. It is the sudden acceleration before the turbo kicking in that cause unburn diesel to release a thick black smoke bomb.
#480
byebye2u
Posted 19 September 2010 - 02:28 AM
byebye2u
  • 2,805 posts
QUOTE (r3xt0n @ Sep 19 2010, 02:14 AM) <{POST_SNAPBACK}>
check the oil level , if grade not compatible sure the engine will consume some. CI-4 and CJ-4 will feel a bit heavier than your current syntetic but will give much more protection.
waaaaaa.. 10 days!!! more than me oooo..( any vacancy ka bro..hihihi)
